1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Allowing localhost in access control files
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 13 Jun 2022 17:13:07 +0200
On Mon, 13 Jun 2022 at 15:27, Simon Rose via Tech-talk <tech-talk at aps.anl.gov> wrote:
Is it possible to set up an access security file to allow only CA/PVA requests from the same host as the IOC? One option of course is to use asSetSubstitutions and some variable, but it seems like there should be a more intrinsic way of doing this.
I have attempted using the name “localhost”, asCheckClientIP set to 1, even using 127.0.0.1 as a member of the host access group, but none of these seemed to work.
My two main questions:
  • Is there a better or more canonical way of doing this?
  • Perhaps more importantly--particularly if we have to use environment variables and substitutions--is there some danger or pitfall about this that we should be careful about?
Actually...
If the only aim is to restrict access to clients on the local machine (e.g. for test environments to not affect other hosts), I would bind the IOC's server to localhost and not use AS.
Cheers,
~Ralph
Re: Allowing localhost in access control files Simon Rose via Tech-talk
Prev: Re: Allowing localhost in access control files Michael Davidsaver via Tech-talk
Next: Re: Allowing localhost in access control files Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
