1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: dbpf error - Operation not permitted at IOC initialization
From: Eric Norum via Tech-talk <tech-talk at aps.anl.gov>
To: "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 14 Jun 2022 14:25:53 -0700
Others with more experience with EPICS database development may have better approaches to this, but for my applications I have:
1 - A periodically-scanned record that reads a value from the attached device:
record(bi, "$(P)$(R)sysmonTrig_") {
    field(DESC, "Trigger system monitor readback")
    field(DTYP, "asynInt32")
    field(INP,  "@asyn($(PORT), 0x0000, 0)")
    field(ZNAM, "Running")
    field(ONAM, "Rebooted")
    field(SCAN, "5 second")
    field(PINI, "YES")
    field(FLNK, "$(P)$(R)reconnChk_")
2 - A calcout record that monitors the status of the periodically-scanned record and invokes an event record when the scanned record goes from bad to good:
# Push values to FPGA on reconnection.
# Monitor the status of a periodically-scanned readback to detect (re)connection.
record(calcout, "$(P)$(R)reconnChk_") {
    field(DESC, "Push on reconnect")
    field(INPA, "$(P)$(R)sysmonTrig_.STAT NPP")
    field(INPD, “1")
    field(CALC, "A=0&&D!=0;D:=A")
    field(OOPT, "When Non-zero")
    field(OUT,  "$(P)$(R)reconnX_.PROC")
record(event, "$(P)$(R)reconnX_") {
    field(DTYP, "Soft Channel")
    field(VAL,  “RECON")
3 - A bunch of fanout records triggered by the above event record — these fanouts trigger the output records to push their values to the device:
record(fanout, "$(P)$(R)BD:rc_") {
    field(DESC, "Push beam dump values on (re)connect")
    field(SCAN, "Event")
    field(EVNT, "RECON")
    field(LNK1, "$(P)$(R)xxxxxxxx")
    field(LNK2, "$(P)$(R)yyyyyyyyy")
    field(LNK3, "$(P)$(R)zzzzzzz”)
On Jun 14, 2022, at 1:20 PM, Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov> wrote:
Based on this, can i assume my links are not connected yet when the first dbpfs are called? How do i debug this kind of problem?
If my links are indeed not connected and i should wait for connection, what is the EPICS recommended way of doing this?
Eric Norum
Re: dbpf error - Operation not permitted at IOC initialization Bernhard Kuner via Tech-talk
dbpf error - Operation not permitted at IOC initialization Marco A. Barra Montevechi Filho via Tech-talk
Prev: dbpf error - Operation not permitted at IOC initialization Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Allowing localhost in access control files Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: dbpf error - Operation not permitted at IOC initialization Bernhard Kuner via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
