1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: CoreRelease and the attributes of an IOC's build
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Wed, 15 Jun 2022 15:25:38 -0500
Hi Matt,
On 6/15/22 3:00 PM, Matt Rippa via Tech-talk wrote:
The coreRelease runtime tool shows the EPICS release info. Any way to query the OS release and build info at runtime? Eg., RTEMS 5.1,  LEGACY_STACK  ?
Thank you!
Matt
> coreRelease
## EPICS R7.0.6.2-DEV
## Rev. 2022-03-28T22:19+0000
We do set some environment variables in the IOC:
2: ARCH=vxWorks-ppc32sf
3: EPICS_VERSION_MAJOR=7
4: EPICS_VERSION_MIDDLE=0
5: EPICS_VERSION_MINOR=6
6: EPICS_VERSION_PATCH=2
7: EPICS_VERSION_SNAPSHOT=-DEV
8: EPICS_VERSION_SITE=
9: EPICS_VERSION_SHORT=7.0.6.2
10: EPICS_VERSION_FULL=7.0.6.2-DEV
There are also have some parameters available from the environment parameter system:
iocanj> epicsPrtEnvParams
EPICS_CA_ADDR_LIST is undefined
EPICS_CA_CONN_TMO: 30.0
EPICS_CA_AUTO_ADDR_LIST: YES
EPICS_CA_REPEATER_PORT: 5065
EPICS_CA_SERVER_PORT: 5064
EPICS_CA_MAX_ARRAY_BYTES: 16384
EPICS_CA_AUTO_ARRAY_BYTES: YES
EPICS_CA_MAX_SEARCH_PERIOD: 300.0
EPICS_CA_NAME_SERVERS is undefined
EPICS_CA_MCAST_TTL: 1
EPICS_CAS_INTF_ADDR_LIST is undefined
EPICS_CAS_IGNORE_ADDR_LIST is undefined
EPICS_CAS_AUTO_BEACON_ADDR_LIST is undefined
EPICS_CAS_BEACON_ADDR_LIST is undefined
EPICS_CAS_SERVER_PORT is undefined
EPICS_CA_BEACON_PERIOD: 15.0
EPICS_CAS_BEACON_PERIOD is undefined
EPICS_CAS_BEACON_PORT is undefined
EPICS_BUILD_COMPILER_CLASS: gcc
EPICS_BUILD_OS_CLASS: vxWorks
EPICS_BUILD_TARGET_ARCH: vxWorks-ppc32sf
EPICS_TZ: CST6CDT,M3.2.0/2,M11.1.0/2
EPICS_TS_NTP_INET is undefined
EPICS_IOC_IGNORE_SERVERS is undefined
EPICS_IOC_LOG_PORT: 7004
EPICS_IOC_LOG_INET is undefined
EPICS_IOC_LOG_FILE_LIMIT: 1000000
EPICS_IOC_LOG_FILE_NAME is undefined
EPICS_IOC_LOG_FILE_COMMAND is undefined
IOCSH_PS1: epics>
IOCSH_HISTSIZE: 50
IOCSH_HISTEDIT_DISABLE is undefined
See envDefs.h for how to get to the compiled-in (default) values of those.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
CoreRelease and the attributes of an IOC's build Matt Rippa via Tech-talk
Prev: CoreRelease and the attributes of an IOC's build Matt Rippa via Tech-talk
Next: RE: Testing Rocky Linux with EPICS Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Some Questions With RTEMS 5 in MVME2502 chengsn via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
