1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Digitizers
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Roehrig, Christian" <roehrig at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 17 Jun 2022 16:17:18 +0000
Hi Chris,
The Teledyne ADQ14 is available with 4 channels and 10 Gb Ethernet interface.  It is 14 bits and up to 2 GHz sample rate.
It is in use with EPICS at APS sectors 1 and 7.
https://www.spdevices.com/documents/datasheets/19-adq14-datasheet/file
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Roehrig, Christian via Tech-talk
Sent: Friday, June 17, 2022 10:59 AM
To: tech-talk at aps.anl.gov
Subject: Digitizers
Hello,
    I am looking for a waveform digitizer that has an ethernet interface, 4 input channels, at least 12-bit ADCs, a sampling rate of at least 10 MS/s, an external trigger input, and existing EPICS support.  Does anyone have a recommendation?  Thank you.
Chris
Christian Roehrig
Principal Controls Engineer
Accelerator Systems Division
Argonne National Laboratory
Office: 630-252-7278
Cell: 630-327-6855
Re: Digitizers Roehrig, Christian via Tech-talk
Prev: RE: Digitizers GAGET Alexis via Tech-talk
Next: Re: Digitizers Roehrig, Christian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
