1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Std and Base duplicate definition of record type
From: João Pedro Burle Ishida via Tech-talk <[email protected]>
Date: Tue, 21 Jun 2022 17:15:48 +0000
Hello,
I'm compiling an IOC which uses std-R3-6, asyn-R4-36,calc-R3-7-3, StreamDevice-2-8-9, autosave-R5-10, seq-2-2-6 and base R3.15.6 to talk to an equipment.
The IOC was compiling until the implementation of doAfterIocInit() of std.dbd, and use the seqSoftIoc.dbd  . Now when I compile appears these errors
perl -CSD /usr/local/epics-nfs/base/R3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/usr/local/epics-nfs/base/R3.15.6/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/calc-R3-7-3/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/StreamDevice-2-8-9/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/autosave-R5-10/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd -I/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6/dbd -o cryostream800.dbd base.dbd std.dbd asyn.dbd calc.dbd drvAsynIPPort.dbd stream.dbd seqSoftIoc.dbd sncExample.dbd
dbdExpand.pl: Duplicate definition of record type 'sub'
Context: recordtype(sub) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd/std.dbd'
  while reading 'std.dbd' to create 'cryostream800.dbd'
dbdExpand.pl: Duplicate definition of record type 'mbbi'
Context: recordtype(mbbi) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6/dbd/seqSoftIoc.dbd' in recordtype(sub) in file '/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/std-R3-6/dbd/std.dbd'
  while reading 'seqSoftIoc.dbd' to create 'cryostream800.dbd'
I need these modules to implement some functions, but I can't figure out if the std.dbd has base.dbd included or how to fix it.
Thanks in advance and good morning,
João P. B. Ishida
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Std and Base duplicate definition of record type Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] phoebus table widget not updating its PV Kasemir, Kay via Tech-talk
Next: RE: Std and Base duplicate definition of record type Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Configuration Parameters with more than 16 states Kasemir, Kay via Tech-talk
