1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Timeout when running soft IOC as root
From: Timo Korhonen via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 27 Jun 2022 19:48:41 +0000
Sorry, I was too quick, should have thought before embarrassing myself ☹. Access to /dev/mem depends on your kernel configuration. Debian probably would not allow access even with this setting (for good reasons.)
Please ignore my post.
Timo
From: Tech-talk <[email protected]> on behalf of Timo Korhonen via Tech-talk <[email protected]>
Reply to: Timo Korhonen <[email protected]>
Date: Monday, 27 June 2022 at 21:33
I know that this does not address the actual question, but you should not need to run the IOC as root even if you need access to /dev/mem.
For example assigning the account under which the IOC is run to the “kmem” group would allow the IOC to access /dev/mem
I would consider that a better practice in any case.
Something like
“sudo usermod -a -G kmem userName”
Logout and login (or reboot) to make the change effective.
Timo
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Reply to: Mark Rivers <[email protected]>
Date: Monday, 27 June 2022 at 19:24
Subject: Timeout when running soft IOC as root
Folks,
I am trying to help Pete Siddons with a problem with an IOC that uses the quadEM module for a BPM he is developing.  It runs EPICS on a Zynq processor.  He says it was working on Debian 7, but is not working on Debian 11.  Because the IOC talks to /dev/mem it needs to run as root.
The driver can be built in simulation mode, so it does not talk to the hardware at all.  In this mode the IOC runs fine when run as a non-privileged user, and takes a total of 3.5 seconds to start up.  This includes the time to create many areaDetector plugins.
However, when running as root there are timeout errors waiting for each of the plugin threads to be created.  The timeout is 2 seconds, and increasing it to 10 seconds does not fix the problem.
This the abbreviated IOC startup output when not running as root.
date
2022/06/27 16:03:39.620634
errlogInit(5000)
< envPaths
epicsEnvSet("IOC","iocNSLS2_IC")
epicsEnvSet("TOP","/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4")
dbLoadDatabase("/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/dbd/quadEMTestApp.dbd")
quadEMTestApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
# Note: the separator between the path entries needs to be changed to a semicolon (;) on Windows
date
2022/06/27 16:03:39.953518
drvNSLS2_ICConfigure("NSLS2_IC", 0, 10000)
Memory mapped
Poller thread created
Creating parameters 0
Poll thread starts
Creating parameters 1
Creating parameters 2
Creating parameters 3
Creating parameters 4
Opening DACS
Getting firmware version
fpgabase=0x569a60
FPGA version=1001
Calling callbacks
date
2022/06/27 16:03:40.129864
# Create 11 statistics plugins
NDStatsConfigure("NSLS2_IC_STATS1", 20, 0, "NSLS2_IC", 0, 0, 0)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDStats.template",     "P=quadEMTest:,R=NSLS2_IC:Current1:, PORT=NSLS2_IC_STATS1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC,NDARRAY_ADDR=0, HIST_SIZE=256,XSIZE=10000,YSIZE=0,NCHANS=1000,ENABLED=1,")
NDTimeSeriesConfigure("NSLS2_IC_STATS1_TS", 20, 0, "NSLS2_IC_STATS1", 1, 23)
NDFFTConfigure("NSLS2_IC_FFT11", 20, 0, "NSLS2_IC_TS1", 10)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosY:,PORT=NSLS2_IC_FFT11,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=10,NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=PosY")
#< $(QUADEM)/iocBoot/saveRestore.cmd
date
2022/06/27 16:03:43.046352
iocInit()
## EPICS R7.0.6.1
## Rev. 2022-03-25T16:17+0000
Gain: 0
Setting bias voltage to 0.000000
date
2022/06/27 16:03:46.982984
# save settings every thirty seconds
#create_monitor_set("auto_settings.req",30,"P=$(PREFIX), R=$(RECORD)")
The IOC starts up fine.  The total time to start is about 3.5 seconds.  There are many plugin threads created during this time.
This the abbreviated IOC startup output when running as root.
date
2022/06/27 14:20:48.298214
errlogInit(5000)
< envPaths
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db:/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/db")
< /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/iocNSLS2_IC/NSLS2_IC.cmd
date
2022/06/27 14:20:48.626216
Memory mapped
Poll thread starts
Opening DACS
fpgabase=0x5809b8
FPGA version=1001
Calling callbacks
date
2022/06/27 14:20:48.802463
< /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/commonPlugins.cmd
# FFT plugins
NDFFTConfigure("NSLS2_IC_FFT1", 20, 0, "NSLS2_IC_TS1", 0)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current1:, PORT=NSLS2_IC_FFT1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=0, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current1")
NDFFTConfigure("NSLS2_IC_FFT2", 20, 0, "NSLS2_IC_TS1", 1)
dbLoadRecords("/home/peter/epics/extensions/synApps/support2022/06/27 14:21:19.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:23.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:26.247 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:21:28.278 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
Starting iocInit
-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current2:, PORT=NSLS2_IC_FFT2, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=1, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current2")
NDFFTConfigure("NSLS2_IC_FFT3", 20, 0, "NSLS2_IC_TS1", 2
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current3:, PORT=NSLS2_IC_FFT3, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=2, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current3")
NDFFTConfigure("NSLS2_IC_FFT4", 20, 0, "NSLS2_IC_TS1", 3)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current4:, PORT=NSLS2_IC_FFT4, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=3, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current4")
NDFFTConfigure("NSLS2_IC_FFT5", 20, 0, "NSLS2_IC_TS1", 4)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumX:, PORT=NSLS2_IC_FFT5, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=4, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumX")
NDFFTConfigure("NSLS2_IC_FFT6", 20, 0, "NSLS2_IC_TS1", 5)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumY:, PORT=NSLS2_IC_FFT6, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=5, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumY")
NDFFTConfigure("NSLS2_IC_FFT7", 20, 0, "NSLS2_IC_TS1", 6)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumAll:, PORT=NSLS2_IC_FFT7, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=6, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumAll")
NDFFTConfigure("NSLS2_IC_FFT8", 20, 0, "NSLS2_IC_TS1", 7)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffX:, PORT=NSLS2_IC_FFT8, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=7, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=DiffX")
NDFFTConfigure("NSLS2_IC_FFT9", 20, 0, "NSLS2_IC_TS1", 8)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffY:, PORT=NSLS2_IC_FFT9, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=8, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=DiffY")
NDFFTConfigure("NSLS2_IC_FFT10", 20, 0, "NSLS2_IC_TS1", 9)
dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosX:,PORT=NSLS2_IC_FFT10,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=9, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=PosX")
date
2022/06/27 14:21:29.253141
iocInit()
## EPICS R7.0.6.1
###########################2022/06/27 14:23:25.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:23:25.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:23:32.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:23:32.244 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:23:34.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_Plugin_1" to exit
was epicsThread object destroyed before thread exit ?
2022/06/27 14:24:05.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:08.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:08.241 quadEMTest:NSLS2_IC:Current2:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:24:10.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_TS_Plugin_1" to exit
2022/06/27 14:24:23.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:23.242 quadEMTest:NSLS2_IC:Current2:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:24:26.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:26.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:28.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:24:35.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:24:51.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:24:51.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:24:53.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:24:54.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:09.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:09.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:11.241 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS7_Plugin_1" to exit
2022/06/27 14:25:26.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:31.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:31.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:31.242 quadEMTest:NSLS2_IC:SumAll:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:25:34.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:34.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:36.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:25:40.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:43.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:43.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:43.243 quadEMTest:NSLS2_IC:DiffX:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:25:45.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:25:47.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:25:47.242 quadEMTest:NSLS2_IC:DiffX:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:25:50.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:25:50.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:25:52.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS9_Plugin_1" to exit
2022/06/27 14:26:04.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:07.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:07.248 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:07.249 quadEMTest:NSLS2_IC:DiffY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:26:09.249 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:26:13.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:13.248 quadEMTest:NSLS2_IC:DiffY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:26:24.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:24.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:26.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:26:35.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:38.249 quadEMTest:NSLS2_IC:PosY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
2022/06/27 14:26:40.250 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS11_TS_Plugin_1" to exit
2022/06/27 14:26:52.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:26:52.242 quadEMTest:NSLS2_IC:PosY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
2022/06/27 14:26:55.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:26:55.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:26:55.243 quadEMTest:NSLS2_IC:image1:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:26:57.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:27:01.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:01.242 quadEMTest:NSLS2_IC:image1:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:15.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:15.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:15.249 quadEMTest:NSLS2_IC:FFT:Current2:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:23.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:23.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:23.243 quadEMTest:NSLS2_IC:FFT:Current4:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:25.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
2022/06/27 14:27:28.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:28.249 quadEMTest:NSLS2_IC:FFT:Current4:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:33.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:33.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:33.249 quadEMTest:NSLS2_IC:FFT:SumX:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:38.249 quadEMTest:NSLS2_IC:FFT:SumY:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:38.249 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:39.240 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:39.241 quadEMTest:NSLS2_IC:FFT:SumAll:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:41.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:41.244 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
2022/06/27 14:27:41.244 quadEMTest:NSLS2_IC:FFT:SumAll:NumThreads devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:45.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:46.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:46.242 quadEMTest:NSLS2_IC:FFT:DiffY:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:47.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:48.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:48.242 quadEMTest:NSLS2_IC:FFT:PosX:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:49.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
2022/06/27 14:27:50.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
2022/06/27 14:27:50.244 quadEMTest:NSLS2_IC:FFT:PosY:QueueSize devAsynInt32::processCallbackOutput process write error
2022/06/27 14:27:53.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:56.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:27:59.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:02.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:05.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
2022/06/27 14:28:11.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
Gain: 0
date
2022/06/27 14:32:29.293229
epics>
There are many errors waiting for plugin threads to start  (and then waiting for them to exit).  The total time to start is about 12 minutes compared to 3.5 seconds when not running as root.
Any ideas why there is an issue creating plugin threads when running as root, but not when running as a normal user?
Timeout when running soft IOC as root Mark Rivers via Tech-talk
Re: Timeout when running soft IOC as root Timo Korhonen via Tech-talk
Prev: Re: Timeout when running soft IOC as root Timo Korhonen via Tech-talk
Next: Re: Timeout when running soft IOC as root Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
