1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: AW: Phoebus connection to alarm server / Kafka
From: "Gotz, Malte via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Jun 2022 07:52:07 +0000
Hi Ian
this: https://control-system-studio.readthedocs.io/en/latest/preference_properties.html#preference-settings
is an overview of all the preferences available for Phoebus, I like to use as a reference. Luckily, alarm is at the very top.
You need to preface the property with the package. So, create a settings file with:
org.phoebus.applications.alarm/server=your.host.com:9092
org.phoebus.applications.alarm/config_name=YourTopic
org.phoebus.applications.alarm/config_names=YourTopic, YourOtherTopic
and pass it to Phoebus with -settings your-settings.ini
Cheers,
Malte
Von: Tech-talk <[email protected]> Im Auftrag von Ian Gillingham via Tech-talk
Gesendet: Dienstag, 28. Juni 2022 09:28
An: [email protected]
Betreff: Phoebus connection to alarm server / Kafka
Hi All,
I have Phoebus , the Phoebus Alarm Server and associated Kafka server (and Zookeeper) initially running on the same Linux dev machine.
It works and Phoebus automatically connects to the running default Kafka topic 'Accelerator'.
I now need to modify it for my own requirements and have used the phoebus/app/alarm/examples/create_alarm_topics.sh script to create a new topic.
I will have Phoebus clients running on Windows machines (on the same network).
Is someone able to point me at the documentation as to where to edit Phoebus configuration to tell it which host:port to connect to for the alarm server (running on a single Linux box) and to change the Kafka topic? It's probably staring me in the face, but I can't find it.
Ian Gillingham
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Phoebus connection to alarm server / Kafka Ian Gillingham via Tech-talk
Prev: Phoebus connection to alarm server / Kafka Ian Gillingham via Tech-talk
Next: Re: Phoebus connection to alarm server / Kafka Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
