1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: added the pv in synapps
To: tech-talk <[email protected]>, 网易邮件中心 <[email protected]>
Date: Tue, 28 Jun 2022 15:44:35 +0000
Correction, scaler16m.db actually requires 5 macro arguments:
$(P)  The prefix
$(S)  The name for this scaler instance
$(FREQ)  The frequency of the clock input
$(DTYP)  The device type.
$(OUT)  The link specification for the hardware connection
Sent: Tuesday, June 28, 2022 9:11 AM
To: tech-talk <[email protected]>;
Subject: Re: added the pv in synapps
> But still failed after I added the command
> "dbLoadRecords("$(STD)/stdApp/Db/scaler16m.db", "P=$(PREFIX)")"
> in st.cmd(common.iocsh)
scaler16m.db requires 2 macro arguments, $(P) and $(S).  You did not pass $(S).  You should change it to something like this:
dbLoadRecords("$(STD)/stdApp/Db/scaler16m.db", "P=$(PREFIX), S=scaler1")
From: Tech-talk <[email protected]> on behalf of 网易邮件中心 via Tech-talk <[email protected]>
Sent: Tuesday, June 28, 2022 8:26 AM
Subject: added the pv in synapps
Hi  all,
     I have a simple question about pv was all disconnected.
I run the xxx ioc, run the opi. But all pv in scaler16m.opi was disconnect.(the ioc did work well)
I typed dbl command, they were not listed, such as xxx:scaler1.S1.
I think the reason was missing some dbLoadRecord of std.
But still failed after I added the command "dbLoadRecords("$(STD)/stdApp/Db/scaler16m.db", "P=$(PREFIX)")" in st.cmd(common.iocsh)
The output of st.cmd:
Warning: '/usr/local/epics/synApps/support/std-R3-6-2/stdApp/Db/scaler16m.db' line 9 has undefined macros
Error: Bad character '$' in Record/Alias name "xxx:$(S,undefined)_calcEnable"
Error at or before ")" in file "/usr/local/epics/synApps/support/std-R3-6-2/stdApp/Db/scaler16m.db" line 9
Error: syntax error
dbLoadRecords: failed to load '/usr/local/epics/synApps/support/std-R3-6-2/stdApp/Db/scaler16m.db'
Could someone tell me what's wrong with me?
I use base 7.0.5,synapps 6.2, opi was control system studio.
Liang
Re: added the pv in synapps 网易邮件中心 via Tech-talk
Re: added the pv in synapps Mark Rivers via Tech-talk
Prev: Re: added the pv in synapps Mark Rivers via Tech-talk
Next: StreamDevice return state error Barrett (US), Patrick E via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: added the pv in synapps 网易邮件中心 via Tech-talk
