1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Doubts about DISS field
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 30 Jun 2022 10:37:12 -0500
Hi Marco,
On 6/30/22 9:19 AM, Marco A. Barra Montevechi Filho wrote:
Thanks for your reply, andrew! It did clarify some doubts.
I did a caget into the record fields and looked at IOC configuration files. Caget in .SDIS returns empty and i found no evidence to believe that SDIS is being configured anywhere. DISV and DISA are also not referenced anywhere, not even in the .db file. Is the severity in DISS field used in any other case? Or just when the record is disabled specifically by DISV, DISA and SDIS fields?
There is only one place in the EPICS source code that uses the value in a record's DISS field, and that code is only activated when DISV == DISA after attempting to read the SDIS link into DISA. If this is what is causing the record to go into alarm state the STAT field will contain DISABLE_ALARM, and the record's timestamp will not be updated because the record has been disabled.
If as you say the SDIS field is empty and the DISA and DISV fields contain their default values of 0 and 1 respectively, the severity in DISS shouldn't be affecting your records at all. I just tested that to confirm.
There must be some other reason the records are going into INVALID alarm. The value in the STAT field should give an indication what that might be — please post the full output from running the command
dbpr "recordname", 4
on the IOC's console for one of those records if you want more advice.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
Re: Doubts about DISS field Andrew Johnson via Tech-talk
Re: Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: Doubts about DISS field Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: [EXTERNAL] Re: PVA monitor request parameters Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: ADEiger R3-12-1 TriggerMode Puzzle John Dobbins via Tech-talk
