1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Timeout when running soft IOC as root
From: "Mooney, Tim M. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Rivers, Mark L." <rivers at cars.uchicago.edu>, Michael Davidsaver <mdavidsaver at gmail.com>, "Siddons, David" <siddons at bnl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 30 Jun 2022 20:07:16 +0000
Hi Pete,
If you're using /dev/mem to read/write memory implemented in the FPGA using an AXI 4 peripheral, you may not have to write a driver, but may be able to use the generic-uio driver.  This allows access from a non-root account, and it allows access by name (which occurs in the device tree) instead of by address, which might change a become a pain in the neck.
Tim Mooney (mooney at anl.gov) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Siddons, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, June 30, 2022 2:25 PM
To: Rivers, Mark L. <rivers at cars.uchicago.edu>; Michael Davidsaver <mdavidsaver at gmail.com>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Michael,
    You are right, of course. I am looking into getting a driver written, but it takes time.
Pete.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, June 27, 2022 9:12 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
On 6/27/22 10:24, Mark Rivers via Tech-talk wrote:
> Folks,
> I am trying to help Pete Siddons with a problem with an IOC that uses the quadEM module for a BPM he is developing.  It runs EPICS on a Zynq processor.  He says it was working on Debian 7, but is not working on Debian 11.
Which Linux kernel variant/version?
>  Because the IOC talks to /dev/mem it needs to run as root.
ick...
I would very much recommend that Pete look at creating a real Linux driver.
mmap()ing "/dev/mem" into an userspace process is playing with fire.
Alternately, adjust file permissions and/or Linux kernel options to bypass
some /dev/mem safety checks (eg. STRICT_DEVMEM and IO_STRICT_DEVMEM)
https://urldefense.com/v3/__https://elixir.bootlin.com/linux/latest/source/lib/Kconfig.debug*L1804__;Iw!!P4SdNyxKAPE!FUgNGKi4r71uFnnc8bN6dWdAsVE564Lgzf5o-sG6kwN9Sen6WKDXYFqb3EbEpUN7LozrwhsWJrOZ-VqJllx9ig$
> The driver can be built in simulation mode, so it does not talk to the hardware at all.  In this mode the IOC runs fine when run as a non-privileged user, and takes a total of 3.5 seconds to start up.  This includes the time to create many areaDetector plugins.
> However, when running as root there are timeout errors waiting for each of the plugin threads to be created.  The timeout is 2 seconds, and increasing it to 10 seconds does not fix the problem.
The quickest way to an answer will probably be gdb (or gdbserver).
Run with a break point set where the "timeout" message is printed[1].
When this is reached, dump all of the thread stacks. (run
"thread apply all backtrace")
This will show if the plugin threads are being created, and if so,
what they are doing.
[1] https://github.com/areaDetector/ADCore/blob/bcaced94ad48b9bb5fdbd1a7f6d9d8be5c416003/ADApp/pluginSrc/NDPluginDriver.cpp#L912
If you haven't encountered gdbserver before, there are two parts.
On the target run something like:
> $ gdbserver 0.0.0.0:3333 ./bin/linux-arm/myioc st.cmd
Then on the (Debian) host run:
> $ gdb-multiarch
> (gdb) target extended-remote <target-ip>:3333
> (gdb) b NDPluginDriver.cpp:912
> (gdb) run
> ... wait for breakpoint
> (gdb) thread apply all backtrace
> ... lots of output ...
> (gdb) quit
The TCP port number can be anything.  3333 is an arbitrary choice.
> This the abbreviated IOC startup output when not running as root.
> date
> 2022/06/27 16:03:39.620634
> errlogInit(5000)
> < envPaths
> epicsEnvSet("IOC","iocNSLS2_IC")
> epicsEnvSet("TOP","/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4")
> dbLoadDatabase("/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/dbd/quadEMTestApp.dbd")
> quadEMTestApp_registerRecordDeviceDriver(pdbbase)
> # The search path for database files
> # Note: the separator between the path entries needs to be changed to a semicolon (;) on Windows
> date
> 2022/06/27 16:03:39.953518
> drvNSLS2_ICConfigure("NSLS2_IC", 0, 10000)
> Memory mapped
> Poller thread created
> Creating parameters 0
> Poll thread starts
> Creating parameters 1
> Creating parameters 2
> Creating parameters 3
> Creating parameters 4
> Opening DACS
> Getting firmware version
> fpgabase=0x569a60
> FPGA version=1001
> Calling callbacks
> date
> 2022/06/27 16:03:40.129864
> # Create 11 statistics plugins
> NDStatsConfigure("NSLS2_IC_STATS1", 20, 0, "NSLS2_IC", 0, 0, 0)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDStats.template",     "P=quadEMTest:,R=NSLS2_IC:Current1:, PORT=NSLS2_IC_STATS1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC,NDARRAY_ADDR=0, HIST_SIZE=256,XSIZE=10000,YSIZE=0,NCHANS=1000,ENABLED=1,")
> NDTimeSeriesConfigure("NSLS2_IC_STATS1_TS", 20, 0, "NSLS2_IC_STATS1", 1, 23)
> NDFFTConfigure("NSLS2_IC_FFT11", 20, 0, "NSLS2_IC_TS1", 10)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosY:,PORT=NSLS2_IC_FFT11,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=10,NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=PosY")
> #< $(QUADEM)/iocBoot/saveRestore.cmd
> date
> 2022/06/27 16:03:43.046352
> iocInit()
> ## EPICS R7.0.6.1
> ## Rev. 2022-03-25T16:17+0000
> iocRun: All initialization complete
> Gain: 0
> Setting bias voltage to 0.000000
> date
> 2022/06/27 16:03:46.982984
> # save settings every thirty seconds
> #create_monitor_set("auto_settings.req",30,"P=$(PREFIX), R=$(RECORD)")
> The IOC starts up fine.  The total time to start is about 3.5 seconds.  There are many plugin threads created during this time.
> This the abbreviated IOC startup output when running as root.
> date
> 2022/06/27 14:20:48.298214
> errlogInit(5000)
> < envPaths
> epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db:/home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/db")
> < /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/iocNSLS2_IC/NSLS2_IC.cmd
> date
> 2022/06/27 14:20:48.626216
> Memory mapped
> Poll thread starts
> Opening DACS
> fpgabase=0x5809b8
> FPGA version=1001
> Calling callbacks
> date
> 2022/06/27 14:20:48.802463
> < /home/peter/epics/extensions/synApps/support-master/synApps/support/quadEM-R9-4/iocBoot/commonPlugins.cmd
> # FFT plugins
> NDFFTConfigure("NSLS2_IC_FFT1", 20, 0, "NSLS2_IC_TS1", 0)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current1:, PORT=NSLS2_IC_FFT1, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=0, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current1")
> NDFFTConfigure("NSLS2_IC_FFT2", 20, 0, "NSLS2_IC_TS1", 1)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support2022/06/27 14:21:19.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:21:23.270 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:21:26.247 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:21:28.278 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> Starting iocInit
> -master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current2:, PORT=NSLS2_IC_FFT2, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=1, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current2")
> NDFFTConfigure("NSLS2_IC_FFT3", 20, 0, "NSLS2_IC_TS1", 2
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current3:, PORT=NSLS2_IC_FFT3, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=2, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current3")
> NDFFTConfigure("NSLS2_IC_FFT4", 20, 0, "NSLS2_IC_TS1", 3)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:Current4:, PORT=NSLS2_IC_FFT4, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=3, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=Current4")
> NDFFTConfigure("NSLS2_IC_FFT5", 20, 0, "NSLS2_IC_TS1", 4)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumX:, PORT=NSLS2_IC_FFT5, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=4, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumX")
> NDFFTConfigure("NSLS2_IC_FFT6", 20, 0, "NSLS2_IC_TS1", 5)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumY:, PORT=NSLS2_IC_FFT6, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=5, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumY")
> NDFFTConfigure("NSLS2_IC_FFT7", 20, 0, "NSLS2_IC_TS1", 6)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:SumAll:, PORT=NSLS2_IC_FFT7, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=6, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=SumAll")
> NDFFTConfigure("NSLS2_IC_FFT8", 20, 0, "NSLS2_IC_TS1", 7)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffX:, PORT=NSLS2_IC_FFT8, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=7, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=DiffX")
> NDFFTConfigure("NSLS2_IC_FFT9", 20, 0, "NSLS2_IC_TS1", 8)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:DiffY:, PORT=NSLS2_IC_FFT9, ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=8, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=DiffY")
> NDFFTConfigure("NSLS2_IC_FFT10", 20, 0, "NSLS2_IC_TS1", 9)
> dbLoadRecords("/home/peter/epics/extensions/synApps/support-master/synApps/support/areaDetector-R3-11/ADCore/db/NDFFT.template","P=quadEMTest:,R=NSLS2_IC:FFT:PosX:,PORT=NSLS2_IC_FFT10,ADDR=0,TIMEOUT=1,NDARRAY_PORT=NSLS2_IC_TS1,NDARRAY_ADDR=9, NCHANS=1000,TIME_LINK=quadEMTest:NSLS2_IC:TS:TSAveragingTime_RBV CP MS,ENABLED=1,NAME=PosX")
> date
> 2022/06/27 14:21:29.253141
> iocInit()
> ## EPICS R7.0.6.1
> ###########################2022/06/27 14:23:25.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:23:25.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:23:32.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:23:32.244 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:23:34.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_Plugin_1" to exit
> was epicsThread object destroyed before thread exit ?
> 2022/06/27 14:24:05.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:24:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:24:08.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:24:08.241 quadEMTest:NSLS2_IC:Current2:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
> 2022/06/27 14:24:10.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS2_TS_Plugin_1" to exit
> 2022/06/27 14:24:23.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:24:23.242 quadEMTest:NSLS2_IC:Current2:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
> 2022/06/27 14:24:26.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:24:26.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:24:28.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:24:35.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:24:51.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:24:51.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:24:53.242 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:24:54.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:25:09.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:25:09.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:25:11.241 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS7_Plugin_1" to exit
> 2022/06/27 14:25:26.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:25:31.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:25:31.242 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:25:31.242 quadEMTest:NSLS2_IC:SumAll:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
> 2022/06/27 14:25:34.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:25:34.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:25:36.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:25:40.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:25:43.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:25:43.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:25:43.243 quadEMTest:NSLS2_IC:DiffX:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
> 2022/06/27 14:25:45.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:25:47.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:25:47.242 quadEMTest:NSLS2_IC:DiffX:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
> 2022/06/27 14:25:50.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:25:50.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:25:52.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS9_Plugin_1" to exit
> 2022/06/27 14:26:04.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:26:07.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:26:07.248 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:26:07.249 quadEMTest:NSLS2_IC:DiffY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
> 2022/06/27 14:26:09.249 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:26:13.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:26:13.248 quadEMTest:NSLS2_IC:DiffY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
> 2022/06/27 14:26:24.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:26:24.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:26:26.243 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:26:35.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:26:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:26:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:26:38.249 quadEMTest:NSLS2_IC:PosY:TS:QueueSize devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=64, value=20
> 2022/06/27 14:26:40.250 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> epicsThread::~epicsThread(): "_main_" blocking for thread "NSLS2_IC_STATS11_TS_Plugin_1" to exit
> 2022/06/27 14:26:52.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:26:52.242 quadEMTest:NSLS2_IC:PosY:TS:NumThreads devAsynInt32::processCallbackOutput process write error NDPluginTimeSeries::writeInt32: status=0, function=67, value=1
> 2022/06/27 14:26:55.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:26:55.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:26:55.243 quadEMTest:NSLS2_IC:image1:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:26:57.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:27:01.240 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:01.242 quadEMTest:NSLS2_IC:image1:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:15.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:15.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:15.249 quadEMTest:NSLS2_IC:FFT:Current2:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:23.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:23.242 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:27:23.243 quadEMTest:NSLS2_IC:FFT:Current4:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:25.244 NDPluginDriver::deleteCallbackThreads timeout waiting for plugin thread 0 exit message
> 2022/06/27 14:27:28.241 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:28.249 quadEMTest:NSLS2_IC:FFT:Current4:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:33.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:33.248 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:33.249 quadEMTest:NSLS2_IC:FFT:SumX:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:38.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:38.249 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:38.249 quadEMTest:NSLS2_IC:FFT:SumY:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:38.249 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
> 2022/06/27 14:27:39.240 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:27:39.241 quadEMTest:NSLS2_IC:FFT:SumAll:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:41.243 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:41.244 NDPluginDriver::writeInt32 ERROR, status=3, function=67, paramName=NUM_THREADS, value=1, connectedToArrayPort_=1
> 2022/06/27 14:27:41.244 quadEMTest:NSLS2_IC:FFT:SumAll:NumThreads devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:45.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
> 2022/06/27 14:27:46.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:27:46.242 quadEMTest:NSLS2_IC:FFT:DiffY:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:47.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
> 2022/06/27 14:27:48.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:27:48.242 quadEMTest:NSLS2_IC:FFT:PosX:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:49.241 NDPluginDriver::deleteCallbackThreads incorrect response from plugin thread 0 = 0
> 2022/06/27 14:27:50.241 NDPluginDriver::writeInt32 ERROR, status=3, function=64, paramName=QUEUE_SIZE, value=20, connectedToArrayPort_=1
> 2022/06/27 14:27:50.244 quadEMTest:NSLS2_IC:FFT:PosY:QueueSize devAsynInt32::processCallbackOutput process write error
> 2022/06/27 14:27:53.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:56.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:27:59.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:28:02.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:28:05.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:28:08.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> 2022/06/27 14:28:11.241 NDPluginDriver::startCallbackThreads timeout waiting for plugin thread 0 start message
> Gain: 0
> date
> 2022/06/27 14:32:29.293229
> epics>
> There are many errors waiting for plugin threads to start  (and then waiting for them to exit).  The total time to start is about 12 minutes compared to 3.5 seconds when not running as root.
> Any ideas why there is an issue creating plugin threads when running as root, but not when running as a normal user?
> Thanks,
> Mark
Re: Timeout when running soft IOC as root Michael Davidsaver via Tech-talk
Timeout when running soft IOC as root Mark Rivers via Tech-talk
Re: Timeout when running soft IOC as root Siddons, David via Tech-talk
Prev: Re: Timeout when running soft IOC as root Siddons, David via Tech-talk
Next: Re: Timeout when running soft IOC as root Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
