1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: areaDetector build errors
From: Jong Woo Kim via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 6 Jul 2022 19:00:07 +0000
Hi Mark,
Thank you. I agree that if there is anything wrong in the file 'RELEASE_PRODS.local', it causes errors like that.
But in this particular case, I realized that re2c was not installed. After I installed it, the problem was solved.
Best,
Jong Woo
Sent: Wednesday, June 22, 2022 6:51 PM
To: Jong Woo Kim <Jong.Woo.Kim at asu.edu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Jong Woo,
Did you follow the installation instructions here:
In particular did you edit RELEASE_PRODS.local to set the path to autosave, calc, etc., (assuming that you want to use them) as documented here:
Sent from my iPhone
On Jun 22, 2022, at 6:19 PM, Jong Woo Kim via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hello,
I just cloned areaDetector, ADCore, ADSupport, ADEiger.
I am using base-3.15.6 and asyn4-38
When I was building areaDetector, I encountered the following errors.
Any ideas?
_____________________________________________________________________
perl -CSD /usr/local/EPICS_NEW/base-3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I../../../../../dbd -I/usr/local/EPICS_NEW/synApps_6_1/support/asyn4-38/dbd -I/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADCore/dbd -I/usr/local/EPICS_NEW/base-3.15.6/dbd -o eigerDetectorApp.dbd eigerDetectorSupport.dbd base.dbd NDPluginSupport.dbd ADSupport.dbd NDFileNull.dbd NDFileNetCDF.dbd NDFileTIFF.dbd NDFileNexus.dbd NDFileHDF5.dbd NDFileJPEG.dbd asyn.dbd asSupport.dbd busySupport.dbd calcSupport.dbd devIocStats.dbd sscanSupport.dbd
dbdExpand.pl: Can't find file 'asSupport.dbd'
  while reading 'asSupport.dbd' to create 'eigerDetectorApp.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/asSupport.dbd
dbdExpand.pl: Can't find file 'busySupport.dbd'
  while reading 'busySupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/busySupport.dbd
dbdExpand.pl: Can't find file 'calcSupport.dbd'
  while reading 'calcSupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/calcSupport.dbd
dbdExpand.pl: Can't find file 'devIocStats.dbd'
  while reading 'devIocStats.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/devIocStats.dbd
dbdExpand.pl: Can't find file 'sscanSupport.dbd'
  while reading 'sscanSupport.dbd' to create 'eigerDetectorApp.dbd'
    $(COMMON_DIR)/eigerDetectorApp.dbd: $(COMMON_DIR)/sscanSupport.dbd
dbdExpand.pl: Exiting due to errors
make[6]: *** [../O.Common/eigerDetectorApp.dbd] Error 2
make[6]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp/src/O.linux-x86_64'
make[5]: *** [install.linux-x86_64] Error 2
make[5]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp/src'
make[4]: *** [src.install] Error 2
make[4]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC/eigerApp'
make[3]: *** [eigerApp.install] Error 2
make[3]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs/eigerIOC'
make[2]: *** [eigerIOC.install] Error 2
make[2]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger/iocs'
make[1]: *** [iocs.install] Error 2
make[1]: Leaving directory `/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger'
make: *** [/usr/local/EPICS_NEW/synApps_6_1/support/areaDetector/ADEiger.install] Error 2
Best,
Jong
areaDetector build errors Jong Woo Kim via Tech-talk
Re: areaDetector build errors Mark Rivers via Tech-talk
Prev: C++ Software Engineer opportunity at ITER Gunion Robert via Tech-talk
Next: Set/get enum value of mbbo from within AD driver Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: areaDetector build errors Mark Rivers via Tech-talk
Next: AreaDetector Teledyne driver question David Vine via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
