1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Set/get enum value of mbbo from within AD driver
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 7 Jul 2022 15:08:49 +0000
Hi Thorsen,
Video would be good. My side
1. Teams
2. Zoom
@Mark Rivers For now I mapped into json, since it is already compiled into the driver. Indeed the 7th choice was incorrect. The enum might not work for this driver because choice 7 exceeds 26 characters in .SVST field of mbbo.
    getIntegerParam(ADTriggerMode, &intNum);
    json triggerMode;
    triggerMode[0] = "PEXSTART_NEXSTOP";
    triggerMode[1] = "NEXSTART_PEXSTOP";
    triggerMode[2] = "PEXSTART_TIMERSTOP";
    triggerMode[3] = "NEXSTART_TIMERSTOP";
    triggerMode[4] = "AUTOTRIGSTART_TIMERSTOP";
    triggerMode[5] = "CONTINUOUS";
    triggerMode[6] = "SOFTWARESTART_TIMERSTOP";
    triggerMode[7] = "SOFTWARESTART_SOFTWARESTOP";
    config_j["TriggerMode"] = triggerMode[intNum];
Kaz
Sent from my T-Mobile 5G Device
Get Outlook for Android
Sent: Thursday, July 7, 2022 10:02:57 AM
Cc: Gofron, Kazimierz <[email protected]>; tech-talk <[email protected]>
Hej Kas and Mark,
I have been doing some kind of work to implement the “metadata interface” for asyn.
For the moment, that is put aside - a lot of stuff is working,
but cleanup is needed, and a review.
Reading this conversation, should we make a video-call, Mark, Kaz ?
BR
/Torsten
> On 7 Jul 2022, at 15:39, Mark Rivers via Tech-talk <[email protected]> wrote:
> > You could store the enum strings and the enum values in a std::set,
> I meant to say std::map, not std::set.
> Mark
> From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
> Sent: Thursday, July 7, 2022 8:35 AM
> To: Gofron, Kazimierz <[email protected]>
> Hi Kaz,
> > In general asyn port drivers don’t have any way of knowing what the mbbo/mbbi enum strings are.
> I should clarify that statement.  It is true if the enum strings are defined in your database file like you showed:
> record(mbbo, "$(P)$(R)TriggerMode")
>    field(ZRST, "PEXSTART_NEXSTOP")
>    field(ZRVL, "0")
>    field(ONST, "NEXSTART_PEXSTOP")
>    field(ONVL, "1")
>    field(TWST, "PEXSTART_TIMERSTOP")
>    field(TWVL, "2")
>    field(THST, "NEXSTART_TIMERSTOP")
>    field(THVL, "3")
>    field(FRST, "AUTOTRIGSTART_TIMERSTOP")
>    field(FRVL, "4")
>    field(FVST, "CONTINUOUS")
>    field(FVVL, "5")
>    field(SXST, "SOFTWARESTART_TIMERSTOP")
>    field(SXVL, "6")
>    field(SVST, "SOFTWARESTART_TIMERSTOP")
>    field(SVVL, "7")
> (Note: it seems you have an error in the database since the last 2 enum strings are identical?)
> However, as I said previously you can define those enum strings and enum values in your driver and populate the record with them if you implement the readEnum() method.  Then your database file will simply look like this:
> In that case your driver will know what the strings are.  You could store the enum strings and the enum values in a std::set, where the enum string is the map key and the enum value is the map value.  For example:
> Put this in the private driver member data.
> std::map<std::string, int> mTriggerModeMap;
> Put this in the constructor.
> mTriggerModeMap["PEXSTART_NEXSTOP"] = 0;
> mTriggerModeMap["NEXSTART_PEXSTOP"] = 1;
> mTriggerModeMap["PEXSTART_TIMERSTOP"] = 2;
> mTriggerModeMap["NEXSTART_TIMERSTOP"] = 3;
> mTriggerModeMap["AUTOTRIGSTART_TIMERSTOP"] = 4;
> mTriggerModeMap["CONTINUOUS"] = 5;
> mTriggerModeMap["SOFTWARESTART_TIMERSTOP"] = 6;
> mTriggerModeMap["SOFTWARESTART_TIMERSTOP"] = 7;
> You can then assign the values with setIntegerParam using the strings:
> This will set the triggerMode parameter to 3:
> setIntegerParam(triggerMode, mTriggerModeMap["NEXSTART_TIMERSTOP"])
> This is my first draft of the readEnum method you would need to add to your driver.
> asynStatus myDriver::readEnum(asynUser *pasynUser, char *strings[], int values[], int severities[],
>                               size_t nElements, size_t *nIn)
>     int function = pasynUser->reason;
>     *nIn = 0;
>     if (function == triggerMode) {
>        for (auto it : mTriggerMap) {
>            if (strings[*nIn]) free(strings[*nIn]);
>            strings[*nIn] = epicsStrDup(it->first.c_str());
>            values[*nIn] = it->second;
>            severities[*nIn] = 0;
>            (*nIn)++;
>     return asynSuccess;
> Mark
> Sent: Wednesday, July 6, 2022 6:00 PM
> Subject: RE: Set/get enum value of mbbo from within AD driver
> Hi Kaz,
> Unfortunately what you want to do is not possible for a number of reasons:
> -          The mbbi record support to device support interface deals only with numbers (RVAL, SHFT, ZRVL, etc.).   Look at the read_mbbi documentation here: https://epics.anl.gov/base/R7-0/6-docs/mbbiRecord.html
> -          For this reason asyn device support only supports the mbbo and mbbi records using the asynInt32 and asunUInt32Digital interfaces, not the asynOctet interface.
> -          In general asyn port drivers don’t have any way of knowing what the mbbo/mbbi enum strings are.  The only method by which those strings can be passed to the driver is via write() method in the asynEnum interface, or equivalently the asynPortDriver::writeEnum() method.  These can pass the enum strings and values to the driver.  However there is currently no device support that actually calls those methods, so drivers have no idea what the enum strings are.
> Mark
> From: Gofron, Kazimierz <[email protected]>
> Sent: Wednesday, July 6, 2022 4:57 PM
> Hi Mark,
> Ad 1: Need to read/set enum string value of mbbo/mbbi record, instead of .VAL field within ADDriver.
> VAL field is read/set with setIntegerParam() and getIntegerParam(), and I am looking for equivalent function for mbbo enum, if they exist.
> Looking for equivalent to setting/reading enum using caget/caput (instead of setting mbbo .VAL to 2), like below:
> setting mbbo:
> gofron@HP/base/bin/linux-x86_64$ ./caput TPX3-TEST:cam1:TriggerMode "PEXSTART_NEXSTOP"
> Old : TPX3-TEST:cam1:TriggerMode     AUTOTRIGSTART_TIMERSTOP
> New : TPX3-TEST:cam1:TriggerMode     PEXSTART_NEXSTOP
> or reading enum string of mbbo record:
> kgofron@kgofron-HP-Z6-G4-Workstation:/epics/src/RHEL8/base/bin/linux-x86_64$ ./caget TPX3-TEST:cam1:TriggerMode
> The mbbo record is defined:
>    field(ZRVL, "0")
>    field(ONVL, "1")
>    field(TWVL, "2")
>    field(THVL, "3")
>    field(FRVL, "4")
>    field(FVVL, "5")
>    field(SXVL, "6")
>    field(SVVL, "7")
> Thanks for looking into this,
> Kaz
> From: Mark Rivers <[email protected]>
> Sent: Wednesday, July 6, 2022 4:13 PM
> Hi Kaz,
> Ø  Is there a way to set/get enum string value of mbbo/mbbi record from within areaDetector driver?
> I want to be clear about what you are asking.  Are you asking whether an areaDetector driver can
> 1)      Select the mbbi value using a string (rather than a number)?
> or
> 2)      Change the string and/or integer value associated with a particular enum index?
> It is not currently possible to do 1), you can only select by number, not by string.
> It is possible to do 2).  That is done with the asynEnum interface.  You implement methods that override one or more of these asynPortDriver methods:
> -          readEnum
> -          writeEnum
> -          doCallbacksEnum
> This is used in many areaDetector drivers so that they can populate the enum strings and values with appropriate values for a particular detector model.  These are some of the drivers that implement readEnum() to set enum strings and values:
> -          andor3.cpp
> -          andorCCD.cpp
> -          ADGenICam.cpp
> -          GenICamFeature.cpp
> -          arvFeature.cpp
> -          ADVimba.cpp
> -          VimbaFeature.cpp
> Mark
> From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
> Sent: Wednesday, July 6, 2022 2:43 PM
> To: [email protected]
> Subject: Set/get enum value of mbbo from within AD driver
> Hi all,
> I can set/get Enum values using caput/caget, but setIntegerParam()/getIntegerParam() which are appropriate for mbbo/mbbi are not appropriate for enum, and setStringParam()/getStrinParam are not compatible with mbbo/mbbi type.
> Also mbbo/mbbi do not have SVAL field, that sCalcoutRecord has.
> Thanks,
> Kaz
Set/get enum value of mbbo from within AD driver Gofron, Kazimierz via Tech-talk
RE: Set/get enum value of mbbo from within AD driver Mark Rivers via Tech-talk
Re: Set/get enum value of mbbo from within AD driver Gofron, Kazimierz via Tech-talk
Re: Set/get enum value of mbbo from within AD driver Mark Rivers via Tech-talk
Re: Set/get enum value of mbbo from within AD driver Torsten Bögershausen via Tech-talk
Prev: RE: EPICS compilation errors Mark Rivers via Tech-talk
Next: RE: EPICS compilation errors Adrian Martinez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Set/get enum value of mbbo from within AD driver Torsten Bögershausen via Tech-talk
Next: EPICS compilation errors Adrian Martinez via Tech-talk
