1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: How to safely implement an asynPortDriver with SCAN records
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Érico Nogueira Rolim <erico.rolim at lnls.br>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 8 Jul 2022 15:23:31 +0000
Hi Érico,
The asynPort driver base class does not have an exit handler to destroy itself when the IOC is exiting, that is left to derived classes.  Does your derived class establish an exit handler with epicsAtExit?
What leads you to believe that the asynPortDriver destructor is being called?
Can you send the actual error trace when the IOC exits?
I just tested with the asyn test applications "testErrors".  That test application uses asynPortDriver.  I modified asyn/iocBoot/ioctestErrors/st.cmd to have these lines uncommented:
dbLoadRecords("../../db/testErrors.db",     "P=testErrors:,PORT=PORT1,ADDR=0,TIMEOUT=1,TSE=0,SCAN=.1 second,FIFO=0")
dbLoadRecords("../../db/testErrorsInt64.db","P=testErrors:,PORT=PORT1,ADDR=0,TIMEOUT=1,TSE=0,SCAN=.1 second,FIFO=0")
That causes the input records to periodically process at 0.1 second scan time.  I have attached a screen shot of the medm screen which shows all of the input records are scanning at 0.1 second.
This is what I see when the IOC exits:
epics> exit
corvette:asyn/iocBoot/ioctestErrors>
So there are no errors when I exit the IOC.  I have tried this a number of times and never see an error.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Érico Nogueira Rolim via Tech-talk
Sent: Friday, July 8, 2022 8:28 AM
To: tech-talk at aps.anl.gov
Subject: How to safely implement an asynPortDriver with SCAN records
Hi!
I have a custom class that inherits from asynPortDriver, but it also overrides the readUInt32Digital, readInt32 and readFloat64 methods, such that they read values from hardware to provide up to date information. Most of our records for this IOC use SCAN set to I/O Intr, and we update values read from hardware when processing writes into hardware. However, we have some records for which we needed to use periodical SCAN ('0.1 second', in this case), due to their monitoring purpose, and they use the aforementioned read* methods to obtain values from hardware.
Unfortunately, when the IOC is exited (with 'exit' in the IOC shell, for example), it seems our asynPortDriver is destroyed before the thread responsible for the record updates is. This leads to multiple use-after-free issues during IOC exit; they can be seen with pthread_mutex_* functions returning EINVAL, and sometimes triggering assertions in our backend.
What is the recommended way forward here? Having things misbehave during exit is not the worst that could happen, but it's still an issue. The alternative I can see is adding a thread that polls through these HW values and using I/O Intr for the records. I think this would always work, but it feels ugly, given that Epics already has periodical SCAN functionality.
Thank you,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Attachment: testErrors.png
Description: testErrors.png
Re: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
Prev: PHP_EPICS module Remi Faure via Tech-talk
Next: Re: Unexpected behavior when setting waveform PVs Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
Next: Re: How to safely implement an asynPortDriver with SCAN records Érico Nogueira Rolim via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
