1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Issue with Asyn+StreamDevice on a Raspi CM4
From: Florian Feldbauer via Tech-talk <[email protected]>
Date: Tue, 12 Jul 2022 09:44:01 +0200
Hey all,
we have a small vacuum chamber to test our sensor modules after production.
The 2 Pumps and 2 valves are controlled via a Raspberry Pi CM4 running linux-aarch64.
The Turbo pump and digital gauge are from Pfeiffer Vacuum and controlled via RS485.
I noticed some strange issue. I was able to read all parameters from those devices, but changing them fails.
To further investigate I attached a 2nd PC to the RS485 bus just listening and found the following:
epics> asynSetTraceIOMask rs485, 0, ASYN_TRACEIO_ESCAPE
epics> asynSetTraceMask rs485, 0, ASYN_TRACEIO_DRIVER
epics> dbpf SCATTERCHAMBER:VACUUM:TP:CtrlViaInt RS485
DBF_STRING:         "RS485"
2022/07/12 09:25:52.084 /dev/ttyAMA0 write 17
0011006003002125\r
2022/07/12 09:25:52.721930 rs485 SCATTERCHAMBER:VACUUM:TP:CtrlViaInt: No reply within 500 ms to "0011006003002125<0d>"
2022/07/12 09:25:52.722 /dev/ttyAMA0 write 16
0010006002=?101\r
2022/07/12 09:25:52.762 /dev/ttyAMA0 read 16
0011006003002125
2022/07/12 09:25:52.766 /dev/ttyAMA0 read 1
\r
epics>
The 2nd PC received this:
Got 16 bytes:
0011006003002125      [30 30 31 31 30 30 36 30 30 33 30 30 32 31 32 35]
Got 16 bytes:
0010006002=?101\r     [30 30 31 30 30 30 36 30 30 32 3d 3f 31 30 31 0d]
Got 17 bytes:
0011006003002125\r    [30 30 31 31 30 30 36 30 30 33 30 30 32 31 32 35 0d]
As you can see, on the first message which was send from the IOC, the CR is missing.
I guess the issue is, that asyn tries to write all 17 bytes at once, but the tx buffer on the Raspberry Pi can only hold 16 byte, so the CR gets lost.
Is there a way to limit the number of bytes written in a single write call with asyn?
Luckily in this case the length of the telegrams is well known and I could simply use 2 OUT statements in my protocol file to work around this problem, but what if I want to control a device where the length depends on the payload data?
Cheers,
Florian
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: Issue with Asyn+StreamDevice on a Raspi CM4 Zimoch Dirk (PSI) via Tech-talk
Prev: Teledyne Dalsa Areadetector Driver Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Teledyne Dalsa Areadetector Driver David Vine via Tech-talk
