1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS compilation errors
From: Andrew Johnson via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Adrian Martinez <[email protected]>
Date: Tue, 12 Jul 2022 10:17:24 -0500
On 7/12/22 7:24 AM, Mark Rivers via Tech-talk wrote:
Hi Adrian,
Your parameter library looks fine before iocInit, but after iocInit all of the parameter names have changed to either an empty string "", or "BPM1".
Does your driver implement the drvUserCreate() method?  If so, that gets called during iocInit and perhaps you have an error in that method.  The names of the parameters should not be changing after they are created.
The only parameter whose name has not changed after iocInit is this one:
Parameter 28 type=asynInt32, name=enable_compensation, value=0, status=0
Perhaps that is a clue?
This description implies that some iocsh callable routine probably needs to make a strcpy() of its parameter name string argument, or to change it from iocshArgString to iocshArgPersistentString in the iocshArg definition (which does that for you).
- Andrew
Complexity comes for free, Simplicity you have to work for.
RE: EPICS compilation errors Mark Rivers via Tech-talk
EPICS compilation errors Adrian Martinez via Tech-talk
RE: EPICS compilation errors Adrian Martinez via Tech-talk
Re: EPICS compilation errors Mark Rivers via Tech-talk
Prev: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Kuldeep Joshi via Tech-talk
Next: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS compilation errors Mark Rivers via Tech-talk
Next: RE: EPICS compilation errors Mark Rivers via Tech-talk
