1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Lowest compatible version of asyn for base 3-15.9
From: Timothy Speight - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
To: "'tech-talk at aps.anl.gov'" <tech-talk at aps.anl.gov>
Date: Tue, 12 Jul 2022 16:02:15 +0000
Is there a suggested version of asyn I can use if I’m not using base 7 but the latest base 3.15?
I see in the latest releases that a lot of the overloads for are using richer type ints that are only served by base 7.
e.g. FtypeUINT64
https://epics.anl.gov/base/R3-15/9-docs/menuFtype.html vs https://epics.anl.gov/base/R7-0/6-docs/menuFtype.html
Kind Regards
Tim Speight
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
RE: Lowest compatible version of asyn for base 3-15.9 Mark Rivers via Tech-talk
Prev: Re: Issue with Asyn+StreamDevice on a Raspi CM4 Florian Feldbauer via Tech-talk
Next: RE: EPICS compilation errors Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Teledyne Dalsa Areadetector Driver (David Vine) David Vine via Tech-talk
Next: RE: Lowest compatible version of asyn for base 3-15.9 Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
