hi, I am using a streamdevice driver to control a power supply. there are about 12 read commands and several setting commands. if use some network debug tools testing, the device can responese each command quickly (around 100ms). But if I use streamdevice driver, there are timeout errors show in attach logfile, even I have set the scan period very slow such as 1 second. ps, if the user send set command to device, when will it happen? after a round query command finishing? thank a lot for your help. attach file download url: https://pan.baidu.com/s/1aBIw8T1NxhH07qTjPCZfMg?pwd=8888
Best wishes
Geyang 2022-07-15
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
