1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: PINI field not working with modbus
To: "[email protected]" <[email protected]>, "Marco A. Barra Montevechi Filho" <[email protected]>
Date: Tue, 26 Jul 2022 13:33:12 +0000
Hi Marco,
Can you show us how the NEG_EMODBUS_1_1_Rd_VTarget port is configured?
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Tuesday, July 26, 2022 7:45 AM
To: [email protected] <[email protected]>
Subject: PINI field not working with modbus
Hello all.
I have an analog in record for reading a modbus register from a device. The record is defined as follows:
record(ai, "${BL}:${H}:${EQ}:TargetVoltRead"){
    field(DESC, "Voltage set on target [V].")
    field(DTYP, "asynInt32")
    field(EGU, "V")
    field(ASLO, 0.01)
    field(INP, "@asyn(NEG_EMODBUS_1_1_Rd_VTarget,0,1000)MODBUS_DATA")
    field(SCAN, "1 second")
Which reads fine. However, if i set the PINI field to YES and the scan to passive:
    field(EGU, "V")
    field(ASLO, 0.01)
    field(SCAN, "Passive")
    field(PINI, "YES")
i get only 0 as value when cagetting the PV. Am i doing something wrong?
Thanks in advance.
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Prev: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: PINI field not working with modbus Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
