1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Delta Tau issue
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Knap, Giles (DLSLtd,RAL,LSCI)" <giles.knap at diamond.ac.uk>, Andy Foster <ajf at observatorysciences.co.uk>
Cc: Peter Eng <peng at uchicago.edu>, Joanne Stubbs <stubbs at cars.uchicago.edu>, tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 28 Jul 2022 22:09:56 +0000
Hi Giles,
Thanks for that info, the PMAC Python GUI is very useful.
This is what I see with it:
So the “Any Memory Checksum Error” bit it set.  I typed the “clrf” command, but that did not clear it.
The system is at the University of Chicago and I am at the APS, so I can’t power-cycle it.  But the next time one of us is there we will try that.
Any suggestion on how to get more information on what checksum is in error?
From: Knap, Giles (DLSLtd,RAL,LSCI) <giles.knap at diamond.ac.uk>
Sent: Tuesday, July 26, 2022 4:06 AM
To: Mark Rivers <rivers at cars.uchicago.edu>; Andy Foster <ajf at observatorysciences.co.uk>
Cc: tech-talk <tech-talk at aps.anl.gov>
Subject: Re: Delta Tau issue
I just noticed that the instructions fail to say that you can install and run with:
  • activate a python virtual env
  • pip install dls-pmaccontrol
  • dls-pmac-control
Sent: 26 July 2022 10:02
Mark,
You may also find that this command will clear the error.
clrf
(Which means clear fault)
For a GUI tool that lets you send arbitrary commands and also shows the status bits see https://dls-controls.github.io/dls-pmac-control
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Andy Foster via Tech-talk <tech-talk at aps.anl.gov>
Sent: 25 July 2022 22:43
Hi Mark,
My understanding of this is that a checksum error has occurred in downloading a program such as a PLC or motion program to the PMAC user buffer space. I think it can also be caused by a download of the firmware, but since you don't do that very often, if ever, unlikely to be that.
In my experience, it needs a power cycle of the logic power to clear that bit.
Cheers, Andy
On Mon, 25 Jul 2022, 21:25 Mark Rivers via Tech-talk, <tech-talk at aps.anl.gov> wrote:
Folks,
I have a Delta Tau GeoBrick 8-channel system.  I have been using it with the Model 2 driver (not based on asynMotorDriver) in the tpmac repository: https://github.com/epics-modules/tpmacc.  I had not seen any errors with that driver.
I have just updated it to use the Model 3 driver (based on asynMotorDriver) in the pmac repository: https://github.com/dls-controls/pmac
The motors seem to be driving OK.  However, the OPI screens show a Controller Error, and the poller prints this message:
2022/07/25 15:10:09.937 pmacController::fastUpdate *** Hardware Problem *** global status [???] => 8400913
The controller error is generated if this _expression_ is non-zero:
const epicsUInt32 pmacController::PMAC_HARDWARE_PROB = (PMAC_GSTATUS_REALTIME_INTR |
                                                        PMAC_GSTATUS_FLASH_ERROR |
                                                        PMAC_GSTATUS_DPRAM_ERROR |
                                                        PMAC_GSTATUS_CKSUM_ERROR |
                                                        PMAC_GSTATUS_WATCHDOG |
                                                        PMAC_GSTATUS_SERVO_ERROR);
That Global Status value 8400913 in hex is 0x803011.  This translates to the following status bits being set:
Bit
Symbolic constant
Problem bit in PMAC_HARDWARE_PROB?
0x1
PMAC_GSTATUS_CARD_ADDR
No
0x10
PMAC_GSTATUS_MACRO_RING_ERRORCHECK
No
0x1000
PMAC_GSTATUS_CKSUM_ACTIVE
No
0x2000
Yes
0x800000
PMAC_GSTATUS_RESERVED3
No
So it appears that the Controller Error on the OPI screen and the error message being printed is because the PMAC_GSTATUS_CKSUM_ERROR bit is set.
Does anyone know what that bit means, and why it might be set?
Delta Tau issue Mark Rivers via Tech-talk
Re: Delta Tau issue Andy Foster via Tech-talk
Re: Delta Tau issue Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: cagateway question Ralph Lange via Tech-talk
Next: EPICS Archiver Appliance - Auto-delete Old Data Rebecca Harding - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Delta Tau issue Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: Delta Tau issue Lazarski, Krzysztof Z. via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
