1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: streamdevice in command only 2048 length
To: 孙彬 <[email protected]>
Date: Tue, 2 Aug 2022 13:57:07 +0000
Is your data binary or ASCII?
Are you using the asynInterpose EOS interface? You can disable it if you don’t need it.
Sent from my iPhone
On Aug 2, 2022, at 8:52 AM, 孙彬 <[email protected]> wrote:
there is asynInterpose.c file has a #define input_size 2048
---Original---
Date: Tue, Aug 2, 2022 21:50 PM
To: "Zimoch Dirk (PSI)"<[email protected]>;
There is no limit in asyn.
How large is your waveform record?
Please share your startup script, database, and protocol file.
Sent from my iPhone
> On Aug 2, 2022, at 8:42 AM, Zimoch Dirk (PSI) via Tech-talk <[email protected]> wrote:
> On Tue, 2022-08-02 at 18:54 +0800, 孙彬 via Tech-talk wrote:
>> Hi,
>> I use streamdevice ,use udp to read a waveform record,but read bytes only 2048,is there configuration to extend the limit?
> There is no limit in StreamDevice. But I am not do familiar with UDP. I guess there is a limit somewhere. Also maybe in
> asyn?
> Dirk
Prev: Re: streamdevice in command only 2048 length Mark Rivers via Tech-talk
Next: Way to know when streamReload has been completed Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
