1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: ADSimDetector-R2-10 build errors with base-7.0.6.1
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Freddie Akeroyd - STFC UKRI <freddie.akeroyd at stfc.ac.uk>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 4 Aug 2022 01:20:14 +0000
My mistake, there was a commit in August 2020 to ADSimDetectorNoIOC.cpp that fixed this problem. That was after R2-10 was released. For now you should use the master branch with base 7.0.6.1.
Sent from my iPhone
On Aug 3, 2022, at 7:57 PM, Freddie Akeroyd - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov> wrote:
Could the error be indicating an issue with the definition of epicsShareClass in the build? The implementation of this in base changed between 7.0.3.1 and 7.0.6.1 as per  https://github.com/epics-base/epics-base/blob/007279cf2905cd006879b780a50faeb592d20cd9/documentation/RELEASE_NOTES.md#_api-macros-in-epics-headers which says an explicit include of shareLib.h might be required in some cases. I can’t say why Mark’s build works if this is the missing, but it might be worth adding an    include <shareLib.h>    to the file and seeing if it helps
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: 03 August 2022 23:53
To: Miceli, Antonino <amiceli at anl.gov>
Cc: Piatak, Christopher <cpiatak at anl.gov>; tech-talk at aps.anl.gov >> EPICS Tech Talk <tech-talk at aps.anl.gov>
I just built the master branch of ADSimDetector with base 7.0.6.1 with no errors on Centos 8.
[epics@viper configure]$ echo $EPICS_HOST_ARCH
linux-x86_64-centos8
[epics@viper configure]$ cd ../ADSimDetector/
[epics@viper ADSimDetector]$ make -sj
I don’t think there are any changes in ADSimDetector between R2-10 and master that should affect this.
Sent from my iPhone
On Aug 3, 2022, at 4:12 PM, Miceli, Antonino via Tech-talk <tech-talk at aps.anl.gov> wrote:
We are having problems building ADSimDetector-R2-10 with base-7.0.6.1. (It builds ok with base-7.0.3.1!)
This is on RHEL8 machine.
Snippet of errors:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I../../../../../include      -I/local/DPbin/epics/epics_2022_06_01/support-R6-2-1/synApps/support/asyn-R4-42/include     -I/local/DPbin/epics/epics_2022_06_01/support-R6-2-1/synApps/support/areaDetector-R3-12-1/ADSupport-R1-10/include/os/Linux -I/local/DPbin/epics/epics_2022_06_01/support-R6-2-1/synApps/support/areaDetector-R3-12-1/ADSupport-R1-10/include   [lots of -l's]       -c ../simDetectorNoIOC.cpp
In file included from ../simDetectorNoIOC.cpp:17:
../../../../../include/simDetector.h:9:35: error: expected initializer before ‘:’ token
 class epicsShareClass simDetector : public ADDriver {
In file included from /local/DPbin/epics/epics_2022_06_01/base-7.0.6.1/include/dbAccess.h:20,
                 from ../simDetectorNoIOC.cpp:24:
/local/DPbin/epics/epics_2022_06_01/base-7.0.6.1/include/dbBase.h:164:22: warning: ‘rset’ is deprecated [-Wdeprecated-declarations]
     rset            *prset;
Nino
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
ADSimDetector-R2-10 build errors with base-7.0.6.1 Miceli, Antonino via Tech-talk
Re: ADSimDetector-R2-10 build errors with base-7.0.6.1 Mark Rivers via Tech-talk
RE: ADSimDetector-R2-10 build errors with base-7.0.6.1 Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: RE: ADSimDetector-R2-10 build errors with base-7.0.6.1 Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Implementing transform field Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
