1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: StreamDevice record locking and processing question
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sat, 6 Aug 2022 11:36:07 +0000
Since "get_voltage" is also asynchronous, will it just simply not do anything until "set_voltage" completes and processes it through the forward-link? I guess my question is more about what "get_voltage" would be doing in this situation while "set_voltage" has the protocol locked.
If get_voltage tries to process because of the 1 second SCAN while set_voltage has the device locked then my understanding is that the following happens:
- get_voltage queues a request to get access to the device
- The queue request has a 5 second timeout by default.
- If set_voltage completes before the 5 second timeout the get_voltage will process.
- If set_voltage takes longer than 5 seconds then the queue request will time out, there will be an error message, and get_voltage will not process from the 1 second scan. But it will process due to FLNK from set_voltage.
Sent from my iPhone
On Aug 6, 2022, at 3:41 AM, Wang, Andrew via Tech-talk <[email protected]> wrote:
Hi all,
This is more of a conceptual question and some insight would be greatly appreciated.
In my EPICS drivers, I employed something an architecture known as "Slow Periodic Scan with Fast Change Response" seen in page 28 (Link: EPICS Re: Recommendations for StreamDevice "architecture" flow (anl.gov)). Thus far, the instruments for which I have written drivers are pretty responsive. However, as I've been using EPICS more and more, I am curious to know more about how StreamDevice handles this particular and possible situation.
Suppose I have a setter and getter for changing the voltage. Using the architecture above, the records can be linked together in the following manner (pseudo-code).
record(fanout, "slow_scan")
      field(SCAN, "1 second")
      field(FLNK, "get_voltage")
record(ao, "set_voltage")
      field(DTYP, "stream")
      field(SCAN, "Passive")
      field(OUT, ...)
record(ai, "get_voltage")
      field(INP, ...)
When I process "set_voltage", a asynchronous passively-scanned record, it will start the protocol in another thread. What if it takes about 5 seconds after the first OUT command is sent to the instrument to receive a reply back. My understanding is that the protocol will lock the device, so no other records can communicate with the instrument. However, in the example above, "get_voltage" will process every 1 second, but won't be allowed access. Since "get_voltage" is also asynchronous, will it just simply not do anything until "set_voltage" completes and processes it through the forward-link? I guess my question is more about what "get_voltage" would be doing in this situation while "set_voltage" has the protocol locked.
Andy
Re: StreamDevice record locking and processing question Zimoch Dirk (PSI) via Tech-talk
StreamDevice record locking and processing question Wang, Andrew via Tech-talk
Prev: StreamDevice record locking and processing question Wang, Andrew via Tech-talk
Next: Re: Question about "indirect processing" mentioned in documentation for the SSEQ Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: StreamDevice record locking and processing question Zimoch Dirk (PSI) via Tech-talk
