1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Asynchronous record processing confusion
From: "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Sun, 7 Aug 2022 19:12:12 +0000
Hi all,
I have another question, but this time it is about Chapter 5 in the Application Developer's Guide regarding asynchronous record processing. In Section 5.9, it states that the asynchronous completion routine performs the following algorithm.
1. Record processing continues
2. Record specific alarm conditions are checked
3. Monitors are raised
4. Forward links are processed
5. PACT is set FALSE.
For step 4, suppose the record is forward-linked to another asynchronous record. Section 5.9.1 and Section 5.9.3  seem to imply that the forward-linked record will be processed after the initial record has completed its processing, particularly from this statement (Forward and output links are triggered only when the asynchronous completion routine completes record processing).
However, in the discussion from Section 5.7, record A doesn't complete processing until all the subsequent records that are forward-linked to A have completed their processing.
I feel like I am missing something, because the understanding I get from the two sections appear to run counter to each other, unless it is because synchronous and asynchronous processing are in fact different from each other and do not share a lot of similarities. However, if the forward-linked records in step 4 need to complete their processing before moving onto Step 5, then it makes more sense.
Again, I really appreciate the time this community takes out of its day to help elucidate these questions I have.
Andy
Re: Asynchronous record processing confusion Mooney, Tim M. via Tech-talk
Prev: Re: Question about "indirect processing" mentioned in documentation for the SSEQ Wang, Andrew via Tech-talk
Next: Re: Asynchronous record processing confusion Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: StreamDevice record locking and processing question Wang, Andrew via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
