Hello all!
I recently tried to upgrade our seq package in our internal build tool
from seq 2.2.6 to seq 2.2.9, and came across an issue.
If I understood correctly, the 2.2.9 version introduces a more modern
RULES_SNCSEQ, which gets installed through CFG, and the old RULES_BUILD
sources the new RULES_SNCSEQ for backwards compatibility.
The way that I'm building it, is by using INSTALL_LOCATION to install
seq in a separate directory, and then drop the original source code.
The issue that I have is that RULES_BUILD and RULES_SNCSEQ are both in
configure/ in the source code, but in the target directory, RULES_BUILD
gets installed in the target configure/, but RULES_SNCSEQ gets
installed under cfg/.
The way RULES_BUILD tries to include RULES_SNCSEQ is by including in
the same directory, which is not the case when using INSTALL_LOCATION.
My current ugly workaround is to have this in RULES_BUILD:
-include $(dir $(lastword $(MAKEFILE_LIST)))/RULES_SNCSEQ
-include $(TOP)/cfg/RULES_SNCSEQ
Which is not optimal since it will silently do nothing if no file is
found.
If I try to always include it from cfg/, the build of seq fails to find
the file, as it does not get installed early enough.
Is it possible to place RULES_SNCSEQ directly under cfg/ in the
upstream source?
Kind regards
Rémi NICOLE <remi.nicole at cea.fr>
CEA/DRF/IRFU/DIS/LDISC
- Re: Issue with RULES_BUILD of seq 2.2.9 Ralph Lange via Tech-talk
- Re: Issue with RULES_BUILD of seq 2.2.9 Han Lee via Tech-talk
Re: pypva, PvObject and NTTable Kuldeep Joshi via Tech-talk
Rocky Linux 8 RPMs Abdalla Ahmad via Tech-talk
<2022>
2025
Re: pypva, PvObject and NTTable Veseli, Sinisa via Tech-talk
<2022>
2025
