The plain "Soft Channel" Device Support does not convert - you would have to write into VAL.
To use RVAL you need to... - use the "Raw Soft Channel" Device Support that converts
- set the LINR field to select the type of conversion you want. (Probably "SLOPE" in your case.)
Also, CP in an OUT link does not make sense - you need PP to trigger the target.
Cheers,
~Ralph
I probably didn't take something into account, but unfortunately I don't see what I did wrong.
I have modified the ai- record from dbExample1.db:
record(ai, "$(user):aiExample")
field(DESC, "Analog input")
# field(INP, "$(user):calcExample.VAL NPP NMS")
field(ASLO, "2")
field(EGU, "Counts")
field(HOPR, "20")
field(LOPR, "0")
field(HIHI, "16")
field(HIGH, "6")
field(LOW, "4")
field(LOLO, "2")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
field(LSV, "MINOR")
field(LLSV, "MAJOR")
and write into this record (RVAL) with a calcout record:
record(calcout, "$(user):dummOut") {
field(INPA, "$(user):calcExample.VAL MS CP")
field(CALC, "A")
field(OUT , "$(user):aiExample.RVAL CP")
RVAL is also changed, but VAL remains 0:
(base) hactar:iocmyExample junkes$ camonitor junkes:aiExample.RVAL junkes:aiExample.VAL junkes:aiExample.ASLO
junkes:aiExample.RVAL 2022-08-11 16:52:57.014817 2 LOLO MAJOR
junkes:aiExample.VAL 2022-08-11 16:52:57.014817 0 LOLO MAJOR
junkes:aiExample.ASLO 2022-08-11 16:52:57.014817 2 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:52:58.016001 3 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:52:59.017708 4 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:53:00.015190 5 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:53:01.017940 6 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:53:02.015414 7 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:53:03.018187 8 LOLO MAJOR
junkes:aiExample.RVAL 2022-08-11 16:53:04.018058 9 LOLO MAJOR
In the record reference manual :
If the device support sets the RVAL field, the LINR field controls how this gets converted into engineering units and placed in the VAL field as follows:
1. RVAL is converted to a double and ROFF is added to it.
2. If ASLO is non-zero the value is multiplied by ASLO.
3. AOFF is added.
Danke, for taking a look,
Heinz
- Re: ai - record unfortunately does not behave as I expect it to Heinz Junkes via Tech-talk
- ai - record unfortunately does not behave as I expect it to Heinz Junkes via Tech-talk
Re: ai - record unfortunately does not behave as I expect it to Florian Feldbauer via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
