1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: areaDetector synchronization question
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 17 Aug 2022 14:28:13 +0200
Hi Folks,
I want to read data from an EPICS control system into another control system.
The setup that I have is as follows:
A Basler camera with 659x495 pixels read out by ADAravis/ADGenICam.
Attached to the driver is a NDStdArraysPlugin and an NDStatsPlugin.
The data will be accesed via an epics gateway process that runs on a gateway
server connecting the local Epics network to the global experiment network
using channel access
I want to read the ArrayData from the NDStdArrayPlugin and the Centroid and
Profile information from the NDStatsPlugin at a rate of 10Hz.
If I read the unique id from both plugins and make sure the are the same, how
big is the chance that the data does not match if I read them in two threads
(thread 1: the  image, thread 2: the stats information)?
Would the situation improve if I can remove the gateway process?
Jörn
Re: areaDetector synchronization question Ralph Lange via Tech-talk
Prev: Re: RTEMS 5 Cannot Read Event Generator Pietryla, Tony via Tech-talk
Next: Re: areaDetector synchronization question Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Re: Re: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
