It’s been a while, but I think I ran `strace make release`, and saw that it stopped on XXX; I forget the exact system call it hung on.
From: Marco A. Barra Montevechi Filho <marco.filho at lnls.br>
Sent: Monday, August 22, 2022 11:04 AM
To: Iain Marcuson <iain.marcuson at sydortechnologies.com>; Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: make release freezes terminal in synApps installation
Right on target!
Thanks for the quick fix, Iain. I dont know why, but it worked.
How did you come to this conclusion?
Best regards,
Marco
I have noticed some similar behavior with synApps 6.1. I believe that I found that commenting out XXX in `configure/RELEASE` allowed `make release` to work.
Thanks for the answer.
I see nothing when interrupting with ctrl+C as shown in attached image.
This seems like some common silly mistake but i cannot figure what am i doing wrong. Thanks for the help.
Marco.
“make release” should only take a few seconds and it should print a lot of information. If you interrupt it with Control-C what do you see?
Im following the areaDetector installation guide (https://areadetector.github.io/master/install_guide.html)
for study purposes and it comes with the assumption that i already have synApps installed.
Since im doing this in my own local machine so i can mess with any code i want without compromising actual operation, im installing synApps from scratch.
Following synApps documentation (https://htmlpreview.github.io/?https://github.com/EPICS-synApps/documentation/blob/R6-1/synApps.html#How%20to%20deploy%20synApps)
i changed synApps/support/configure/RELEASE to add EPICS_BASE and SUPPORT paths. I didnt edit
support/configure/EPICS_BASE.<arch> or support/configure/SUPPORT
because i dont plan to build for more than one architecture and comparing this folder with other compilations of synApps that i found in other machines from my lab, i saw that this folder was unchanged in these compilations. Same goes for ipac and motor modules.
My EPICS_HOST_ARCH env var is set to linux-x86_64, which matches my local machine.
Inside synApps_6_1/support i run make release. It does nothing but freezing my terminal.
Im aware that there are many modules to be compiled and much to be done, but shouldnt it at least print something? Am i doing something wrong?
I tried checking to Makefile and i found:
release:
echo EPICS_BASE=$(EPICS_BASE)
echo MASTER_FILE=$(MASTER_FILE)
echo RELEASE_FILES=$(RELEASE_FILES)
$(PERL) $(TOP)/configure/makeReleaseConsistent.pl $(SUPPORT) $(EPICS_BASE) $(MASTER_FILE) $(RELEASE_FILES)
So im guessing it uses the variable EPICS_BASE (and others) to configure other makefiles. But shouldnt it have printed the result of $EPICS_BASE in my terminal, then? Im checking it in my terminal with echo $EPICS_BASE and it works, resulting in "/home/marco/EPICS/epics-base"
Thanks in advance for any help.
Marco.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes
de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before
copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Click
here to report this email as spam.
This message has been scanned for malware by Forcepoint.
www.forcepoint.com
- make release freezes terminal in synApps installation Marco A. Barra Montevechi Filho via Tech-talk
- Re: make release freezes terminal in synApps installation Mark Rivers via Tech-talk
- Re: make release freezes terminal in synApps installation Marco A. Barra Montevechi Filho via Tech-talk
- RE: make release freezes terminal in synApps installation Iain Marcuson via Tech-talk
SynApps compilation error Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
Help LE-DANIEL Erwann via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
