1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Wed, 24 Aug 2022 01:22:17 +0000
Hello all.
Im trying to compile areaDetector-R3-7 in my machine. After following this tutorial: (https://areadetector.github.io/master/install_guide.html) and turning every WITH_GRAPHICSMAGICK variable to NO to avoid problems with VP8LDelete and similar functions, im facing the compiling error that i append in the end of this email. It seems to be originated in areaDetector-R3-7/ADCore/ADApp/pluginSrc.
Searching for answers i found this answer: (https://epics.anl.gov/tech-talk/2017/msg00990.php) but i dont think its the same as my problem since EPICS_BASE is correctly defined in my configure/RELEASE_LIBS.local, configure/RELEASE_BASE.local and configure/RELEASE_PRODS.local. My version of areaDetector also didnt come with the files EXAMPLE_RELEASE_PATHS.local and EXAMPLE_CONFIG_SITE.local.
Does anyone have any hints on how to proceed? Thanks in advance.
Compilation message when done inside areaDetector-R3-7/ADCore/ADApp/pluginSrc:
areaDetector-R3-7/ADCore/ADApp/pluginSrc$ make
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/ADApp/pluginSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall    -DHAVE_JPEG -DHAVE_BLOSC -DHAVE_BITSHUFFLE -DH5_NO_DEPRECATED_SYMBOLS -DH5Gopen_vers=2  -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/marco/EPICS/synApps_6_1/support/asyn-R4-36/include     -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADSupport/include/os/Linux -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADSupport/include   -I/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/include -I/home/marco/EPICS/epics-base/include/compiler/gcc -I/home/marco/EPICS/epics-base/include/os/Linux -I/home/marco/EPICS/epics-base/include        -c ../NDArrayRing.cpp
In file included from ../../../include/NDArray.h:20,
                 from ../NDArrayRing.h:4,
                 from ../NDArrayRing.cpp:19:
../../../include/NDAttribute.h:87:23: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type
   87 | class epicsShareClass NDAttribute {
../../../include/NDAttribute.h:88:1: error: expected primary-_expression_ before ‘public’
   88 | public:
../../../include/NDAttribute.h:88:1: error: expected ‘}’ before ‘public’
../../../include/NDAttribute.h:87:35: note: to match this ‘{’
../../../include/NDAttribute.h:88:1: error: expected ‘,’ or ‘;’ before ‘public’
   88 | public:
../../../include/NDAttribute.h:92:16: error: expected constructor, destructor, or type conversion before ‘(’ token
   92 |     NDAttribute(NDAttribute& attribute);
../../../include/NDAttribute.h:94:13: error: declaration of ‘~ NDAttribute’ as non-member
   94 |     virtual ~NDAttribute();
../../../include/NDAttribute.h:95:13: error: ‘NDAttribute’ does not name a type
   95 |     virtual NDAttribute* copy(NDAttribute *pAttribute);
../../../include/NDAttribute.h:96:5: error: ‘virtual’ outside class declaration
   96 |     virtual const char *getName();
../../../include/NDAttribute.h:97:5: error: ‘virtual’ outside class declaration
   97 |     virtual const char *getDescription();
../../../include/NDAttribute.h:98:5: error: ‘virtual’ outside class declaration
   98 |     virtual const char *getSource();
../../../include/NDAttribute.h:99:5: error: ‘virtual’ outside class declaration
   99 |     virtual const char *getSourceInfo(NDAttrSource_t *pSourceType);
../../../include/NDAttribute.h:100:5: error: ‘virtual’ outside class declaration
  100 |     virtual NDAttrDataType_t getDataType();
../../../include/NDAttribute.h:101:5: error: ‘virtual’ outside class declaration
  101 |     virtual int getValueInfo(NDAttrDataType_t *pDataType, size_t *pDataSize);
../../../include/NDAttribute.h:102:5: error: ‘virtual’ outside class declaration
  102 |     virtual int getValue(NDAttrDataType_t dataType, void *pValue, size_t dataSize=0);
../../../include/NDAttribute.h:103:5: error: ‘virtual’ outside class declaration
  103 |     virtual int getValue(std::string& value);
../../../include/NDAttribute.h:104:5: error: ‘virtual’ outside class declaration
  104 |     virtual int setDataType(NDAttrDataType_t dataType);
../../../include/NDAttribute.h:105:5: error: ‘virtual’ outside class declaration
  105 |     virtual int setValue(const void *pValue);
../../../include/NDAttribute.h:106:5: error: ‘virtual’ outside class declaration
  106 |     virtual int setValue(const std::string&);
../../../include/NDAttribute.h:107:5: error: ‘virtual’ outside class declaration
  107 |     virtual int updateValue();
../../../include/NDAttribute.h:108:5: error: ‘virtual’ outside class declaration
  108 |     virtual int report(FILE *fp, int details);
../../../include/NDAttribute.h:109:5: error: ‘friend’ used outside of class
  109 |     friend class NDArray;
../../../include/NDAttribute.h:110:5: error: ‘friend’ used outside of class
  110 |     friend class NDAttributeList;
../../../include/NDAttribute.h:113:1: error: expected unqualified-id before ‘private’
  113 | private:
../../../include/NDAttribute.h:124:1: error: expected declaration before ‘}’ token
  124 | };
In file included from ../../../include/NDArray.h:21,
../../../include/NDAttributeList.h:21:23: error: variable ‘epicsShareClass NDAttributeList’ has initializer but incomplete type
   21 | class epicsShareClass NDAttributeList {
../../../include/NDAttributeList.h:22:1: error: expected primary-_expression_ before ‘public’
   22 | public:
../../../include/NDAttributeList.h:22:1: error: expected ‘}’ before ‘public’
../../../include/NDAttributeList.h:21:39: note: to match this ‘{’
../../../include/NDAttributeList.h:22:1: error: expected ‘,’ or ‘;’ before ‘public’
   22 | public:
../../../include/NDAttributeList.h:24:23: error: expected constructor, destructor, or type conversion before ‘;’ token
   24 |     ~NDAttributeList();
../../../include/NDAttributeList.h:25:35: error: ‘pAttribute’ was not declared in this scope; did you mean ‘NDAttribute’?
   25 |     int          add(NDAttribute *pAttribute);
      |                                   NDAttribute
../../../include/NDAttributeList.h:26:5: error: ‘NDAttribute’ does not name a type
   26 |     NDAttribute* add(const char *pName, const char *pDescription="",
../../../include/NDAttributeList.h:28:5: error: ‘NDAttribute’ does not name a type
   28 |     NDAttribute* find(const char *pName);
../../../include/NDAttributeList.h:29:5: error: ‘NDAttribute’ does not name a type
   29 |     NDAttribute* next(NDAttribute *pAttribute);
../../../include/NDAttributeList.h:33:40: error: ‘pOut’ was not declared in this scope
   33 |     int          copy(NDAttributeList *pOut);
../../../include/NDAttributeList.h:37:1: error: expected unqualified-id before ‘private’
   37 | private:
../../../include/NDAttributeList.h:40:1: error: expected declaration before ‘}’ token
   40 | };
In file included from ../NDArrayRing.h:4,
../../../include/NDArray.h:92:23: error: variable ‘epicsShareClass NDArray’ has initializer but incomplete type
   92 | class epicsShareClass NDArray {
../../../include/NDArray.h:93:1: error: expected primary-_expression_ before ‘public’
   93 | public:
../../../include/NDArray.h:93:1: error: expected ‘}’ before ‘public’
../../../include/NDArray.h:92:31: note: to match this ‘{’
../../../include/NDArray.h:93:1: error: expected ‘,’ or ‘;’ before ‘public’
   93 | public:
../../../include/NDArray.h:96:90: error: expected constructor, destructor, or type conversion before ‘;’ token
   96 |     NDArray(int ndims, size_t *dims, NDDataType_t dataType, size_t dataSize, void *pData);
../../../include/NDArray.h:97:13: error: declaration of ‘~ NDArray’ as non-member
   97 |     virtual ~NDArray();
../../../include/NDArray.h:103:38: error: non-member function ‘int getReferenceCount()’ cannot have cv-qualifier
  103 |     int          getReferenceCount() const {return referenceCount;}
../../../include/NDArray.h: In function ‘int getReferenceCount()’:
../../../include/NDArray.h:103:52: error: ‘referenceCount’ was not declared in this scope; did you mean ‘getReferenceCount’?
      |                                                    getReferenceCount
../../../include/NDArray.h: At global scope:
../../../include/NDArray.h:105:5: error: ‘friend’ used outside of class
  105 |     friend class NDArrayPool;
../../../include/NDArray.h:107:1: error: expected unqualified-id before ‘private’
  107 | private:
../../../include/NDArray.h:111:1: error: expected unqualified-id before ‘public’
  111 | public:
../../../include/NDArray.h:127:5: error: ‘NDAttributeList’ does not name a type
  127 |     NDAttributeList *pAttributeList;  /**< Linked list of attributes */
../../../include/NDArray.h:130:1: error: expected declaration before ‘}’ token
  130 | };
../../../include/NDArray.h:142:32: error: expected ‘)’ before ‘*’ token
  142 |         freeListElement(NDArray *pArray, size_t dataSize) {
../../../include/NDArray.h:148:9: error: ‘NDArray’ does not name a type
  148 |         NDArray *pArray_;
../../../include/NDArray.h:161:23: error: variable ‘epicsShareClass NDArrayPool’ has initializer but incomplete type
  161 | class epicsShareClass NDArrayPool {
../../../include/NDArray.h:162:1: error: expected primary-_expression_ before ‘public’
  162 | public:
../../../include/NDArray.h:162:1: error: expected ‘}’ before ‘public’
../../../include/NDArray.h:161:35: note: to match this ‘{’
../../../include/NDArray.h:162:1: error: expected ‘,’ or ‘;’ before ‘public’
  162 | public:
../../../include/NDArray.h:164:13: error: declaration of ‘~ NDArrayPool’ as non-member
  164 |     virtual ~NDArrayPool() {}
../../../include/NDArray.h:165:5: error: ‘NDArray’ does not name a type
  165 |     NDArray*     alloc(int ndims, size_t *dims, NDDataType_t dataType, size_t dataSize, void *pData);
../../../include/NDArray.h:166:5: error: ‘NDArray’ does not name a type
  166 |     NDArray*     copy(NDArray *pIn, NDArray *pOut, bool copyData, bool copyDimensions=true, bool copyDataType=true);
../../../include/NDArray.h:168:26: error: ‘int reserve’ redeclared as different kind of entity
  168 |     int          reserve(NDArray *pArray);
../../../include/NDArray.h:101:18: note: previous declaration ‘int reserve()’
  101 |     int          reserve();
../../../include/NDArray.h:168:35: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
      |                                   NDArray
../../../include/NDArray.h:169:26: error: ‘int release’ redeclared as different kind of entity
  169 |     int          release(NDArray *pArray);
../../../include/NDArray.h:102:18: note: previous declaration ‘int release()’
  102 |     int          release();
../../../include/NDArray.h:169:35: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
      |                                   NDArray
../../../include/NDArray.h:170:35: error: ‘pIn’ was not declared in this scope
  170 |     int          convert(NDArray *pIn,
../../../include/NDArray.h:171:36: error: ‘ppOut’ was not declared in this scope
  171 |                          NDArray **ppOut,
../../../include/NDArray.h:172:39: error: expected primary-_expression_ before ‘dataTypeOut’
  172 |                          NDDataType_t dataTypeOut,
../../../include/NDArray.h:173:40: error: expected primary-_expression_ before ‘*’ token
  173 |                          NDDimension_t *outDims);
../../../include/NDArray.h:173:41: error: ‘outDims’ was not declared in this scope
../../../include/NDArray.h:173:48: error: _expression_ list treated as compound _expression_ in initializer [-fpermissive]
../../../include/NDArray.h:174:18: error: redefinition of ‘int convert’
  174 |     int          convert(NDArray *pIn,
../../../include/NDArray.h:170:18: note: ‘int convert’ previously defined here
../../../include/NDArray.h:174:35: error: ‘pIn’ was not declared in this scope
../../../include/NDArray.h:175:36: error: ‘ppOut’ was not declared in this scope
  175 |                          NDArray **ppOut,
../../../include/NDArray.h:176:39: error: expected primary-_expression_ before ‘dataTypeOut’
  176 |                          NDDataType_t dataTypeOut);
../../../include/NDArray.h:184:1: error: expected unqualified-id before ‘protected’
  184 | protected:
../../../include/NDArray.h:189:5: error: ‘virtual’ outside class declaration
  189 |     virtual void onAllocateArray(NDArray *pArray);
../../../include/NDArray.h:189:18: error: variable or field ‘onAllocateArray’ declared void
../../../include/NDArray.h:189:43: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
      |                                           NDArray
../../../include/NDArray.h:190:5: error: ‘virtual’ outside class declaration
  190 |     virtual void onReserveArray(NDArray *pArray);
../../../include/NDArray.h:190:18: error: variable or field ‘onReserveArray’ declared void
../../../include/NDArray.h:190:42: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
      |                                          NDArray
../../../include/NDArray.h:191:5: error: ‘virtual’ outside class declaration
  191 |     virtual void onReleaseArray(NDArray *pArray);
../../../include/NDArray.h:191:18: error: variable or field ‘onReleaseArray’ declared void
../../../include/NDArray.h:191:42: error: ‘pArray’ was not declared in this scope; did you mean ‘NDArray’?
      |                                          NDArray
../../../include/NDArray.h:193:1: error: expected unqualified-id before ‘private’
  193 | private:
../../../include/NDArray.h:200:1: error: expected declaration before ‘}’ token
  200 | };
In file included from ../NDArrayRing.cpp:19:
../NDArrayRing.h:20:5: error: ‘NDArray’ does not name a type
   20 |     NDArray *addToEnd(NDArray *pArray);
../NDArrayRing.h:23:5: error: ‘NDArray’ does not name a type
   23 |     NDArray *readFromStart();
../NDArrayRing.h:26:5: error: ‘NDArray’ does not name a type
   26 |     NDArray *readNext();
../NDArrayRing.h:36:5: error: ‘NDArray’ does not name a type
   36 |     NDArray** buffers_;
../NDArrayRing.cpp: In constructor ‘NDArrayRing::NDArrayRing(int)’:
../NDArrayRing.cpp:24:3: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
   24 |   buffers_ = NULL;
      |   numBuffers_
../NDArrayRing.cpp:29:18: error: ‘NDArray’ does not name a type
   29 |   buffers_ = new NDArray *[noOfBuffers_];
../NDArrayRing.cpp:29:28: error: capture of non-variable ‘NDArrayRing::noOfBuffers_’
../NDArrayRing.h:39:10: note: ‘int NDArrayRing::noOfBuffers_’ declared here
   39 |     int  noOfBuffers_;
../NDArrayRing.cpp: In lambda function:
../NDArrayRing.cpp:29:41: error: expected ‘{’ before ‘;’ token
../NDArrayRing.cpp: In destructor ‘NDArrayRing::~NDArrayRing()’:
../NDArrayRing.cpp:38:12: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
   38 |   delete[] buffers_;
      |            numBuffers_
../NDArrayRing.cpp: At global scope:
../NDArrayRing.cpp:49:1: error: ‘NDArray’ does not name a type
   49 | NDArray *NDArrayRing::addToEnd(NDArray *pArray)
../NDArrayRing.cpp:71:1: error: ‘NDArray’ does not name a type
   71 | NDArray *NDArrayRing::readFromStart()
../NDArrayRing.cpp:83:1: error: ‘NDArray’ does not name a type
   83 | NDArray *NDArrayRing::readNext()
../NDArrayRing.cpp: In member function ‘void NDArrayRing::clear()’:
../NDArrayRing.cpp:104:7: error: ‘buffers_’ was not declared in this scope; did you mean ‘numBuffers_’?
  104 |   if (buffers_){
      |       numBuffers_
../../../include/NDAttribute.h: At global scope:
../../../include/NDAttribute.h:93:24: warning: ‘const char* attrSourceString(NDAttrSource_t)’ declared ‘static’ but never defined [-Wunused-function]
   93 |     static const char *attrSourceString(NDAttrSource_t type);
../../../include/NDArray.h:99:18: warning: ‘int computeArrayInfo(int, size_t*, NDDataType_t, NDArrayInfo*)’ declared ‘static’ but never defined [-Wunused-function]
   99 |     static int   computeArrayInfo(int ndims, size_t *dims, NDDataType_t dataType, NDArrayInfo *pInfo);
make[1]: *** [/home/marco/EPICS/epics-base/configure/RULES_BUILD:267: NDArrayRing.o] Error 1
make[1]: Leaving directory '/home/marco/EPICS/synApps_6_1/support/areaDetector-R3-7/ADCore/ADApp/pluginSrc/O.linux-x86_64'
make: *** [/home/marco/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Michael Davidsaver via Tech-talk
Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Mark Rivers via Tech-talk
Prev: Recommended amplifiers/drivers for GALIL motor controllers? Jesse Hopkins via Tech-talk
Next: Re: Help compiling AreaDetector: error: variable ‘epicsShareClass NDAttribute’ has initializer but incomplete type Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: [Ext] RE: [EXTERNAL] Recommended amplifiers/drivers for GALIL motor controllers? Jesse Hopkins via Tech-talk
