1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: setInteger64Param
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: "Gofron, Kazimierz" <[email protected]>, Mark Rivers <[email protected]>
Date: Fri, 26 Aug 2022 12:39:25 +0000
Hej Kaz
>>I wonder if "ai" record is correct for asyInt64.
Of course not ;-)
Please try
record(int64in, "$(P)$(R)StartTime_RBV"){
  field(DTYP, "asynInt64")
  field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))TPX3_START_TIME")
  field(SCAN, "I/O Intr")
/Torsten
From: Tech-talk <[email protected]> on behalf of "Gofron, Kazimierz via Tech-talk" <[email protected]>
Reply-To: "Gofron, Kazimierz" <[email protected]>
Date: Friday, 26 August 2022 at 14:18
Hi Mark,
Sorry, I copied a wrong record to the previous email.
The correct record is
record(ai, "$(P)$(R)StartTime_RBV"){
setInteger64Param(ADTimePixStartTime,       1661466046253);
createParam(ADTimePixStartTimeString,       asynParamInt64,     &ADTimePixStartTime);
The callParamCallbacks(); was there. I added additional one just after the setInteger64Param()
Kaz
Sent: Thursday, August 25, 2022 11:56 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected] <[email protected]>
I just noticed that you created the parameter with Type asynInt64 but your record has DTYP asynFloat64. That is not correct, and should have produced an error message after iocInit.
You should either use an ai record with DTYP asynInt64 or an int64In record.
Sent from my iPhone
On Aug 25, 2022, at 6:42 PM, Gofron, Kazimierz via Tech-talk <[email protected]> wrote:
Hi all,
I am writing an areaDetector driver that reads integer time in multiples of fractions of ns.
ADCore: R3-11
asyn:    R4-22
OS:         ubuntu 20.04LTE
record(ai, "$(P)$(R)ElapsedTime_RBV"){
  field(DTYP, "asynFloat64")
  field(INP, "@asyn($(PORT),$(ADDR),$(TIMEOUT))TPX3_ELAPSED_TIME")
In the driver the value is set using (hard coded value here):
However, the PV value does not change from 0.
PV is created:
The caput changes the value of PV:
kgofron@myHP$ caput TPX3-TEST:cam1:StartTime_RBV 1661466046253
Old : TPX3-TEST:cam1:StartTime_RBV   0
New : TPX3-TEST:cam1:StartTime_RBV   1.66147e+12
Any suggestions would be much appreciated.
Kazimierz
Re: setInteger64Param Mark Rivers via Tech-talk
setInteger64Param Gofron, Kazimierz via Tech-talk
Re: setInteger64Param Gofron, Kazimierz via Tech-talk
Prev: Eurotherm modbus support William Kirstaedter via Tech-talk
Next: Re: Eurotherm modbus support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: setInteger64Param Gofron, Kazimierz via Tech-talk
Next: Re: setInteger64Param Mark Rivers via Tech-talk
