1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Eurotherm modbus support
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: William Kirstaedter <kirstaedter at fhi-berlin.mpg.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 26 Aug 2022 14:04:01 +0000
Thanks for sharing the source.
Can you post the errors you get when renaming the .c file to .cpp?
It looks like the C file is mainly a convenience function for creating the Modbus drivers. Most if not all of that could probably be done in the startup script instead.  But I can see what needs to be done to make it work with the current version of the Modbus driver.
Sent from my iPhone
On Aug 26, 2022, at 8:41 AM, William Kirstaedter <kirstaedter at fhi-berlin.mpg.de> wrote:
Hi Mark,
unfortunately, it doesnt work, various casts fail.
I've saved a dump here: https://gitlab.fhi.mpg.de/kw/eurotherm2k
(should be externally accessible)
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 26.08.22 um 14:40 schrieb Mark Rivers:
Hi William,
You can probably just rename eurothermModbus.c to eurothermModbus.cpp.  See if that works.
How does eurothermModbus use drvModbusAsyn?
From: Tech-talk on behalf of William Kirstaedter via Tech-talk
Sent: Friday, August 26, 2022 7:20 AM
To: tech-talk at aps.anl.gov
Subject: Eurotherm modbus support
unfortunately the DLS site for the eurotherm support module is not available anymore...
(http://controls.diamond.ac.uk/downloads/support/eurotherm2k/)
does anybody still maintain eurotherms?
I kinda converted the 1-22 release to work with my environment and am now running into a C / C++ error...
newer asyn versions reference vector.h which is C++ while my eurotherm support file is C, which is bad because the C compiler doesnt know about the C++ vector.h ...
In file included from /home/epics/EPICS/epics-support/modbus/include/drvModbusAsyn.h:15,
                 from ../eurothermModbus.c:25:
/home/epics/EPICS/epics-support/asyn/include/asynPortDriver.h:4:10: fatal error: vector: No such file or directory
 #include <vector>
compilation terminated.
Im not sure how to get around this....
maybe someone with more experience in the EPICS build system can help me out.
thanks,
William
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: kirstaedter at fhi-berlin.mpg.de
Re: Eurotherm modbus support Mark Rivers via Tech-talk
Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Prev: Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Next: RE: Eurotherm modbus support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
