1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Eurotherm modbus support
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, William Kirstaedter <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 26 Aug 2022 16:49:52 +0000
Hi Mark,
This repo is a backup of an IOC instance we had running that as far as I could tell had no upstream master (I believe it was downloaded as a source tarball, probably from the DLS site). I was planning on getting it working with the newer modbus version at some point, which it seems you have already done, perhaps we should just apply those changes to the repo?
Best,
Jakub
Sent: Friday, August 26, 2022 12:24 PM
To: William Kirstaedter <[email protected]>; [email protected] <[email protected]>; Wlodek, Jakub <[email protected]>
Subject: RE: Eurotherm modbus support
I now realize that DLS repository is not the same as the one you are using.  However, this one does seem to be the same:
https://github.com/jwlodek/eurotherm2k
Jakub, is this repository a fork of a master somewhere else, or is this now the primary repository?
Sent: Friday, August 26, 2022 11:08 AM
Hi William,
It appears that the eurothemModbus source code is on Github here:
https://github.com/dls-controls/eurothermModbus
Does your gitlab dump differ from that?
Sent: Friday, August 26, 2022 8:41 AM
To: Mark Rivers <[email protected]>; [email protected]
Hi Mark,
unfortunately, it doesnt work, various casts fail.
I've saved a dump here: https://gitlab.fhi.mpg.de/kw/eurotherm2k
(should be externally accessible)
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 26.08.22 um 14:40 schrieb Mark Rivers:
Hi William,
You can probably just rename eurothermModbus.c to eurothermModbus.cpp.  See if that works.
How does eurothermModbus use drvModbusAsyn?
From: Tech-talk on behalf of William Kirstaedter via Tech-talk
Sent: Friday, August 26, 2022 7:20 AM
To: [email protected]
Subject: Eurotherm modbus support
unfortunately the DLS site for the eurotherm support module is not available anymore...
(http://controls.diamond.ac.uk/downloads/support/eurotherm2k/)
does anybody still maintain eurotherms?
I kinda converted the 1-22 release to work with my environment and am now running into a C / C++ error...
newer asyn versions reference vector.h which is C++ while my eurotherm support file is C, which is bad because the C compiler doesnt know about the C++ vector.h ...
In file included from /home/epics/EPICS/epics-support/modbus/include/drvModbusAsyn.h:15,
                 from ../eurothermModbus.c:25:
/home/epics/EPICS/epics-support/asyn/include/asynPortDriver.h:4:10: fatal error: vector: No such file or directory
 #include <vector>
compilation terminated.
Im not sure how to get around this....
maybe someone with more experience in the EPICS build system can help me out.
thanks,
William
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
RE: Eurotherm modbus support Mark Rivers via Tech-talk
Re: Eurotherm modbus support Mark Rivers via Tech-talk
Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Prev: RE: Eurotherm modbus support Mark Rivers via Tech-talk
Next: RE: Eurotherm modbus support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
