Hi
How much is it important to set the SHRLIB_VERSION when building support modules? I know it is set by default to the base version when building EPICS base but it seems it is optional when building any support modules. I did this test in
our RPM setup, I had all support modules built using asyn 4.41 and I deployed an RPM for asyn 4.42, doing “yum install stream-device” failed because it explicitly asked for asyn 4.41 “libasyn.so.4.41”. I unset the variable in the base and removed it in the
support modules, it did update asyn and installed any module that uses asyn, but I am wondering how much this would affect compatibility and dependencies between modules.
Abdalla
- Re: SHRLIB_VESION Variable Andrew Johnson via Tech-talk
- Re: SHRLIB_VESION Variable Michael Davidsaver via Tech-talk
RE: setInteger64Param Mark Rivers via Tech-talk
Re: Eurotherm modbus support William Kirstaedter via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
