1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: EPICS on ESP32
From: Florian Feldbauer via Tech-talk <[email protected]>
Date: Tue, 30 Aug 2022 11:52:37 +0200
Hey all,
for a small side project I'm working with a board featuring an ESP32-WROOM-32E module [1]. The module itself has WiFi and an EMAC core which is connected to an ethernet PHY on the board (10/100Mbps).
Also there are some sensors connected to the module.
At the moment I have a small program running on the board, that connects to ethernet, gets it's IP via DHCP and starts listening on a TCP port.
If a message is received the corresponding sensor data is send as an answer.
The chip is running a modified FreeRTOS kernel and I started to wonder, if it would be possible to port EPICS on that module.
Does anyone have experience with the ESP32 and tried running EPICS on it already?
If not, anyone has an idea for a good starting point for such a project?
A CA server that provides the sensor data as PVs would be enough.
Cheers,
Florian
[1] https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32e_esp32-wroom-32ue_datasheet_en.pdf
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: EPICS on ESP32 Michael Davidsaver via Tech-talk
Re: EPICS on ESP32 Eric Norum via Tech-talk
Re: EPICS on ESP32 Davis, Mark via Tech-talk
Prev: Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Next: Re: EPICS on ESP32 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: SHRLIB_VESION Variable Michael Davidsaver via Tech-talk
