1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: asyn build fail
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, "Li, Ji" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 31 Aug 2022 23:06:43 +0000
Hi Yong,
  Yes, but this wonderful EPICS community always comes through with the solution in record time 🙂
Pete.
Sent: Wednesday, August 31, 2022 7:02 PM
To: Li, Ji <[email protected]>; [email protected] <[email protected]>; Siddons, David <[email protected]>
Hi Pete, this happened to many people, including me. I guess this will continue trip other people. See this report: https://github.com/epics-modules/asyn/issues/95.
It would be nice if this kind of compile error could be fixed in future asyn release.
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Li, Ji via Tech-talk <[email protected]>
Date: Wednesday, August 31, 2022 at 3:09 PM
To: [email protected] <[email protected]>, Siddons, David <[email protected]>
Hi Pete,
You can uncomment this line in CONFIG_SITE of asyn:
# TIRPC=yes
Then the compiler should be able to look for this file in /usr/include/tirpc/.
Best,
-Ji
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Wednesday, August 31, 2022 14:56
Subject: asyn build fail
I am provisioning a new machine (Ubuntu 22.04), and have installed and built base-3.15.9. I'm now installing synApps, and the build failed  when building asyn, see below:
make[3]: Entering directory '/home/peter/epics/synApps/support/asyn-R4-42/asyn/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API  -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall    -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC  -mtune=generic    -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/home/peter/epics/synApps/support/ipac-2-16/include   -I/home/peter/epics/synApps/support/seq-2-2-9/include -I/home/peter/epics/base-3.15.9/include/compiler/gcc -I/home/peter/epics/base-3.15.9/include/os/Linux -I/home/peter/epics/base-3.15.9/include        -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
    9 | #include <rpc/rpc.h>
compilation terminated.
The file /usr/include/rpc/rpc.h does not exist. There is a file /usr/include/tirpc/rpc/rpc.h. Should I simply copy the files into /usr/include? Or edit the offending source files to point to these new locations?
Pete.
Re: asyn build fail Andrew Johnson via Tech-talk
asyn build fail Siddons, David via Tech-talk
Re: asyn build fail Li, Ji via Tech-talk
Re: asyn build fail Hu, Yong via Tech-talk
Prev: Re: asyn build fail Hu, Yong via Tech-talk
Next: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: asyn build fail Andrew Johnson via Tech-talk
