1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Epics archiver appliance freezing
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Thu, 1 Sep 2022 14:11:16 +0000
>> Is there a specific log to look into to see the freeze up, most of the logs I’ve checked out have tons of information but not sure what I am searching for as the culprit
I would first look in the mgmt's ( and subsequently the other component's) localhost logs to determine which request is causing the issue. Once you narrow down the request; you can look in the code/try adding additional log statements etc. Check for anything related to out of memory etc. Does restarting fix this issue temporarily? Also, did you check the browser's console log for any client side exception?
>> but it just will not return anything status wise about the PV search.
I think most of this is done in memory on the mgmt instance. However; the cluster needs to be active and alive for this to work correctly. So any info on actions that takes the cluster down ( out of memory, for example) would help.
Murali
RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Prev: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Next: Re: asyn build fail Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
