1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Getting a time series of some NDPluginStats
To: Iain Marcuson <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 8 Sep 2022 15:29:32 +0000
> On that related note, I also have a separate datum that I want to put into a time series.  At present I write that value out on its own NDArray Address.  Do I then use that address in the NDTimeSeriesConfigure line later?
Yes, that is correct.  You can actually put more than 1 datum in an array, which is what NDPluginStats does.  This is documented here:
There are other example drivers that use NDPluginTimeSeries in ADCSimDetector (https://github.com/areaDetector/ADCsimdetector) and in quadEM (https://github.com/epics-modules/quadEM)
Sent: Thursday, September 8, 2022 8:58 AM
To: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Subject: RE: Getting a time series of some NDPluginStats
It looks like that would solve the problem.  Part of my reason for asking is that I am trying to get a better sense of how the various areaDetector plugins work and fit together.
Sent: Thursday, September 08, 2022 9:26 AM
To: [email protected]; Iain Marcuson <[email protected]>
Hi Iain,
> I would like to be able to do the time series of the X and Y centroids.
The time series of the X and Y centroids is easy.  This is a screen shot of the NDPluginStats screen.
In the Centroid section there is a menu labeled "Time series plots".  Simply select "Centroid X" and you will see a plot like this:
Maybe I am not understanding the question?
From: Tech-talk <[email protected]> on behalf of Iain Marcuson via Tech-talk <[email protected]>
Sent: Thursday, September 8, 2022 7:26 AM
To: [email protected] <[email protected]>
Subject: Getting a time series of some NDPluginStats
For a project, I successfully have NDPluginStats computing the profile and centroid of an image.  I would like to be able to do the time series of the X and Y centroids.  I have been looking at the synApps QuadEM as a starting point, and it seems that in QuadEM the positions are output on specific NDArray Addresses, while that is not the case with NDPluginStats.  Is there some way to select only the centroids of the NDPluginStats to put into a time series?
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 | www.SydorTechnologies.com
Skype: [email protected]
This message has been scanned for malware by Forcepoint. www.forcepoint.com
Click here to report this email as spam.
Getting a time series of some NDPluginStats Iain Marcuson via Tech-talk
Re: Getting a time series of some NDPluginStats Mark Rivers via Tech-talk
RE: Getting a time series of some NDPluginStats Iain Marcuson via Tech-talk
Prev: RE: Getting a time series of some NDPluginStats Pearson, Matthew via Tech-talk
Next: EPICS 7.0.7 Released Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Clog 2.0 released Wang, Lin via Tech-talk
