HI Andy,
On 9/15/22 4:23 AM, Ralph Lange via Tech-talk wrote:
I
am wondering if it is possible to have a record
process only when the exit command is sent to the IOC
Shell.
Have a look at the different options for the PINI field.
That's probably as close as you can get without coding.
Unfortunately PINI doesn't have a shutdown choice at all, which
comes from the history that embedded IOCs didn't need to handle
releasing resources at shut-down, so the IOC shutdown process wasn't
very well defined.
I think the only way to do what you're wanting is to have some code
register an epicsAtExit()
routine as late as possible, either from an st.cmd command after
iocInit or from initHookAfterIocRunning, and for its routine to
trigger record processing. I would suggest having it call postEvent(eventNameToHandle("exit"))
(after including dbScan.h to declare those routines) which would
trigger all records that have SCAN="Event" and EVNT="exit".
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Process a record only when IOC shell exits Wang, Andrew via Tech-talk
- Re: Process a record only when IOC shell exits Ralph Lange via Tech-talk
Re: Question regarding synApps:delaygen Mark Rivers via Tech-talk
Re: Yokogawa DL350 Wang, SuYin Grass via Tech-talk
<2022>
2025
Question regarding synApps:delaygen Jörn Dreyer via Tech-talk
<2022>
2025
ANJ, 15 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
