1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: warnings.warn from raspberry pyepics
To: LE-DANIEL Erwann <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Sep 2022 15:42:49 +0000
Please try creating the PV object outside the loop. There is no need to keep creating it.
Sent from my iPhone
On Sep 19, 2022, at 10:36 AM, LE-DANIEL Erwann <[email protected]> wrote:
Hello,
It depends, but not exactly 10 seconds.
During tests, the time.sleep is quite respected for the 15 first return, and after time between return raise until error message.
Cordialement,
LE DANIEL Erwann.
De : Mark Rivers <[email protected]>
Envoyé : lundi 19 septembre 2022 17:30
À : LE-DANIEL Erwann <[email protected]>
Cc : [email protected]; [email protected]
Objet : Re: warnings.warn from raspberry pyepics
Vous ne recevez pas souvent de courriers de la part de [email protected]. Découvrez pourquoi cela est important
CAUTION: This email was sent from outside Alstom. Be vigilant if you want to click on links or open attachments.
When you say it runs 10 seconds does it work correctly during that time, printing that values? Or does it just hang for 10 seconds?
You can print additional information about p after you create it, like whether it is connected to the PV.
Sent from my iPhone
On Sep 19, 2022, at 7:18 AM, LE-DANIEL Erwann via Tech-talk <[email protected]> wrote:
Hello,
I’m using a raspberry to get epics variable value from that code :
import epics
import time
while True:
               p=epics.PV(‘TL_AN_Input’)
               val = p.get()
               print (val)
               time.sleep(0.1)
This code runs about 10 seconds and after it returns the error message :
/home/pi/.local/lib/python3.9/site-packages/epics/ca.py:1528: UserWarning: ca.get(‘TL_AN_Input…’) timed out after 1.00 seconds.
Warnings.warn(msg % (name(chid), timeout))
What does it mean ?
Is it because I need to clean the PV_cache ?  è if it is the case how can I do that ?
Thank you very much.
Cordialement,
LE DANIEL Erwann.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may be privileged. If you are not a named recipient, please notify the sender immediately and do not disclose the contents to another person, use it for any purpose or store or copy the information in any medium.
In case of strong suspicion of phishing, report the email through the reporting tool on your Outlook toolbar or send it as an attachment to [email protected]
warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Re: warnings.warn from raspberry pyepics Mark Rivers via Tech-talk
RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Prev: Re: Strange memory leak with ADAravis Mark Rivers via Tech-talk
Next: Re: warnings.warn from raspberry pyepics Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
