1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: warnings.warn from raspberry pyepics
To: LE-DANIEL Erwann <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Sep 2022 16:22:39 +0000
caRepeater is not important for this test.
Did you try moving the creation of p outside of the loop?
Sent from my iPhone
On Sep 19, 2022, at 11:11 AM, LE-DANIEL Erwann <[email protected]> wrote:
Other point,
When I start the script, this message occure :
The executable “caRepeater” couldn’t be located
Because of errno = “No such file or directory”
You may need to modify your PATH environment variable
Unable to start “CA Repeater” process
Is this message linked to the other ??
Cordialement,
LE DANIEL Erwann.
De : Tech-talk <[email protected]> De la part de LE-DANIEL Erwann via Tech-talk
Envoyé : lundi 19 septembre 2022 17:58
À : Mark Rivers <[email protected]>; Matthew Newville <[email protected]>
Cc : [email protected]; [email protected]
Objet : RE: warnings.warn from raspberry pyepics
CAUTION: This email was sent from outside Alstom. Be vigilant if you want to click on links or open attachments.
True, It works and return values from network during few seconds and after the loop speed decrease and the error message occures.
Cordialement,
LE DANIEL Erwann.
De : Mark Rivers <[email protected]>
Envoyé : lundi 19 septembre 2022 17:53
À : Matthew Newville <[email protected]>
Cc : LE-DANIEL Erwann <[email protected]>; [email protected]; [email protected]
Objet : Re: warnings.warn from raspberry pyepics
Vous ne recevez pas souvent de courriers de la part de [email protected]. Découvrez pourquoi cela est important
If I understood his last message correctly it works OK printing values for 10 seconds, and then it fails.  So it does find the PV.
Sent from my iPhone
On Sep 19, 2022, at 10:46 AM, Matt Newville via Tech-talk <[email protected]> wrote:
Hi Le Daniel,
I would guess that the PV is actually not being found on the network.  Is EPICS_CA_ADDR_LIST set so that the IOC or CA server providing that PV can be found?
On Mon, Sep 19, 2022 at 7:18 AM LE-DANIEL Erwann via Tech-talk <[email protected]> wrote:
Hello,
I’m using a raspberry to get epics variable value from that code :
import epics
import time
while True:
               p=epics.PV(‘TL_AN_Input’)
               val = p.get()
               print (val)
               time.sleep(0.1)
This code runs about 10 seconds and after it returns the error message :
/home/pi/.local/lib/python3.9/site-packages/epics/ca.py:1528: UserWarning: ca.get(‘TL_AN_Input…’) timed out after 1.00 seconds.
Warnings.warn(msg % (name(chid), timeout))
What does it mean ?
Is it because I need to clean the PV_cache ?  è if it is the case how can I do that ?
Thank you very much.
Cordialement,
LE DANIEL Erwann.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may be privileged. If you are not a named recipient, please notify the sender immediately and do not disclose the contents to another person, use it for any purpose or store or copy the information in any medium.
--Matt Newville
In case of strong suspicion of phishing, report the email through the reporting tool on your Outlook toolbar or send it as an attachment to [email protected]
RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Re: warnings.warn from raspberry pyepics Matt Newville via Tech-talk
Re: warnings.warn from raspberry pyepics Mark Rivers via Tech-talk
Prev: RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Next: Re: warnings.warn from raspberry pyepics Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
