1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, Ralph Lange <ralph.lange at gmx.de>
Date: Mon, 26 Sep 2022 15:13:06 +0000
On Mon, 26 Sept 2022 at 15:02, Shankar, Murali via Tech-talk <tech-talk at aps.anl.gov> wrote:
The EAA uses camonitors for both SCAN and MONITOR requests.
> If that's the case (noticeable change of behavior compared to the older archivers) - what is the difference between the two options?
I don't think it's a change from the Channel Archiver nor the RDB-based archive engine.
MONITOR:  Channel uses monitor (for ADEL threshold) and tries to save every received value.
SCAN:  Channel uses monitor (for ADEL threshold) and then saves the most recently received value every SCAN period.
SCAN does not perform a get or get-callback every SCAN period, and it also doesn't save the time of when it was scanned.
Instead, it would for example scan once every 5 minutes, and then write whatever the most recently received sample was .. if it changed.
-Kay
Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Re: How to archive PVs regularly even if they are not updating Shankar, Murali via Tech-talk
Prev: Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 26 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
