I am developing an EPICS asyn stream device for a Hirst Magnetics GM08 handheld unit and probe. I think I have tied down my development and my MVP is going to be just reading a stream that is polling every second, without me sending an RS232 command down the line. It is a fairly simple device communicating at 9600,N,8,1 and I can use screen /dev/ttyS0 9600 in Ubuntu 20.00 to have the device send back terminated data. Looks a bit like this where the left float is a milliTesla and the 300 is stated units. 00.020 300CrLf 00.002 300CrLf -0.001 300CrLf When I try to hook this up to stream and asyn using the latest devices against drvSerial and with the debug loaded. I’m having a hard time getting the INP to read the data I have turned on asynTraceMask and get no chatter, plus used the stream debug to see it connect on /dev/ttyS0 at the permissionable addressed Linux COM1 on my motherboard. I get something with not being able to instantiate the PV when I do a dbtr HIRST1:current_value. Has anyone developed EPICS against this? Or would a kind person take a glance at my IOC development? Kind Regards Tim Speight
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
