1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] 1D Histogram in Phoebus
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: Florian Feldbauer <florian at ep1.ruhr-uni-bochum.de>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 28 Sep 2022 12:16:02 +0000
Hi:
> Is it also possible to introduce some sort of binning with the XY-Plot widget?
> (e.g. combining 2 or 4 values into 1 bar?)
You'd have to perform the binning on the IOC, for example using a histogram record.
Note that in case you don't want to update the "real" IOC that has the raw data, you can place the histogram record (or whatever else you use) on a separate IOC.
The general idea for the display is that it's just the display. It shows data from PVs, and it allows operators to write to PVs.
It should not "do" anything. It shouldn't perform automation or create new data, because then you run into issues when you launch zero or more than one instances of the display. Suddenly your automation is gone, or your various instances of the same display show different data because they were started at different times etc.
If you perform your binning on an IOC, all displays will show the same histogram data. You can also fetch it via caget or from some python script to perform additional computations, again resting assured that it's the same histogram data that you see on the display.
-Kay
1D Histogram in Phoebus Florian Feldbauer via Tech-talk
Re: [EXTERNAL] 1D Histogram in Phoebus Kasemir, Kay via Tech-talk
Re: [EXTERNAL] 1D Histogram in Phoebus Florian Feldbauer via Tech-talk
Prev: Re: [EXTERNAL] 1D Histogram in Phoebus Florian Feldbauer via Tech-talk
Next: DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: error during building synapps module Siddharth Vardhan Pratihast via Tech-talk
ANJ, 28 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
