1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Understanding EPICS DSET-based driver
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Sun, 2 Oct 2022 10:29:16 +0000
Hi
I am trying to write an EPICS driver by using the device support model explained in the app developer guide. I attached a preliminary code for the ai record which only increments the record’s value by a value passed in the INP field. My question is, for the read_ai function I had to return 2 in order for the driver to work, otherwise the record’s value will not change. Why is that? In page 192 of the developer guide, return 2 means do not convert, what does it mean in this case? Also, is implementing a callback to process the record necessary? Or can I lock/unlock the record directly in the read_ai function?
Thanks!
Abdalla.
#include <stdio.h>
#include <string.h>
#include <stdbool.h>
#include <stdlib.h>
#include <callback.h>
#include <aiRecord.h>
#include <recSup.h>
#include <devSup.h>
#include <dbAccess.h>
#include <epicsExport.h>
static int increment_value;
static long init_record(struct aiRecord* record)
	if(record->inp.type != INST_IO) {
		printf("Invalid record type\n");
		return -1;
	printf("INP: %s\n", record->inp.value.instio.string);
	char* token = strtok(record->inp.value.instio.string, " ");
	if(token == NULL) {
		printf("Invalid INP string");
		return -2;
	token = strtok(NULL, " ");
	increment_value = atoi(token);
	record->dpvt = (void*) &increment_value;
	return 0;
static long read_ai(struct aiRecord* record)
	int* value = (int*) record->dpvt;
	if(record->pact) {
		record->val = record->val + *value;
		record->udf = false;
		printf("Completed processing. Value %f\n\n", record->val);
		return 2;
	record->pact = true;
	dbScanLock((struct dbCommon*) record);
	(record->rset->process)(record);
	dbScanUnlock((struct dbCommon*) record);
	return 2;
struct {
	long number;
	DEVSUPFUN report;
	DEVSUPFUN init;
	DEVSUPFUN init_record;
	DEVSUPFUN get_ioinit_info;
	DEVSUPFUN io;
	DEVSUPFUN misc;
} devai = {
	6,
	NULL,
	NULL,
	init_record,
	NULL,
	read_ai,
	NULL
epicsExportAddress(dset, devai);
Re: Understanding EPICS DSET-based driver Michael Davidsaver via Tech-talk
Prev: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Understanding EPICS DSET-based driver Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: EPICS mrfioc2 and new mtca card EVRTM-300 Žiga Oven via Tech-talk
