1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: EPICS Base 3.14.12.8 build error on CentOS 9
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
Date: Thu, 6 Oct 2022 08:36:52 +0000
I tried to build EPICS Base 3.14.12.8,
 succeed on CentOS 8 (GCC version 8.5.0, make version 4.2.1);
 failed on CentOS 9 (GCC version 11.3.1, make version 4.3).
It seemed the error is related to C++ private/protected access specifiers.
 I guess that the reason is because CentOS 9's newer GCC has tightened some rules.
After modifying a file "src/cas/generic/ioBlocked.h", at  line 43:
    class ioBlockedList : private tsDLList<ioBlocked> {
changed to
    class ioBlockedList : protected tsDLList<ioBlocked> {
Then the build succeed.
My question: is  the above modification a proper fix to correct this build error.
The build log:
In file included from ../../../../src/cas/generic/caServer.cc:21:
../../../../src/cas/generic/caServerI.h: At global scope:
../../../../src/cas/generic/caServerI.h:91:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
91 | tsDLList < casStrmClient > clientList;
In file included from ../../../../src/cas/generic/caServerI.h:33,
../../../../src/cas/generic/ioBlocked.h:43:7: note: declared private here
43 | class ioBlockedList : private tsDLList<ioBlocked> {
../../../../src/cas/generic/caServerI.h:92:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
92 | tsDLList < casIntfOS > intfList;
make[4]: *** [../../../../configure/RULES_BUILD:220: caServer.o] Error 1
make[4]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas/build/O.linux-x86_64'
make[3]: *** [../../../configure/RULES_ARCHS:61: install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas/build'
make[2]: *** [../../configure/RULES_DIRS:83: build.install] Error 2
make[2]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas'
make[1]: *** [../configure/RULES_DIRS:83: cas.install] Error 2
make[1]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src' make: *** [configure/RULES_DIRS:83: src.install] Error 2
Best regards.
LiangChih Chiang
NSRRC Beamline group
Re: EPICS Base 3.14.12.8 build error on CentOS 9 Maren Purves via Tech-talk
Prev: Re: Exploring EPICS performance/processing limits Matt Newville via Tech-talk
Next: Re: EPICS 7 side-by-side with EPICS 3/4 Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Exploring EPICS performance/processing limits Ralph Lange via Tech-talk
Next: Re: EPICS Base 3.14.12.8 build error on CentOS 9 Maren Purves via Tech-talk
