1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Fri, 7 Oct 2022 10:34:25 +0900
I encounter an error while building an EPICS 3.15.6 base with vxWorks-6.9 for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32, see error messages below.
I changed each PATH
  1. /base-3.15.6/configure/CONFIG_SITE
    • CROSS_COMPILER_TARGET_ARCHES : vxWorks-ppc32
  2. Base-3.15.6/configure/os/CONFIG_SITE.Common.vxWorksCommon
    • VXWORKS_VERSION = 6.9
    • WIND_BASE = /home/abcd/WindRiver/vxworks-6.9
Like this.
And then make the epics_base-3.15.6, it shows me this kind of make error:
make[3]: /home/abcd/WindRiver/vxworks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc: Command not found
make[3]: *** [vxComLibrary.o] Error 127
make[3]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom/O.vxWorks-ppc32'
make[2]: *** [install.vxWorks-ppc32] Error 2
make[2]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src'
make: *** [src.install] Error 2
I’d like to know how can I fix this error
Thank you.
Re: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32 Wang, Lin via Tech-talk
Prev: RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
Next: Re: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32 Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: point pcaspy to EPICS 7 Wang Xiaoqiang (PSI) via Tech-talk
