1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: point pcaspy to EPICS 7
From: "Gregory, Ray via Tech-talk" <[email protected]>
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Date: Fri, 7 Oct 2022 16:35:36 +0000
Hi Xiaoqiang,
Thanks for the info.
Does this mean that I would need to build pcaspy from source to get it to use EPICS 7?
And that the binary version of pcaspy that I installed previously is using the version of EPICS I was using (what EPICS_BASE pointed to) when I installed it?
Thank you,
Ray
Ray Gregory
Oak Ridge National Laboratory
-----Original Message-----
Sent: Friday, October 07, 2022 8:28 AM
To: Gregory, Ray <[email protected]>
Cc: [email protected]
Subject: [EXTERNAL] Re: point pcaspy to EPICS 7
Hi Ray,
Here is the steps I use to build PCAS module together with EPICS base.
hxxps://pcaspy.readthedocs.io/en/latest/installation.html#getting-epics
Best
Xiaoqiang
> On 6 Oct 2022, at 20:19, Gregory, Ray via Tech-talk <[email protected]> wrote:
> Hi,
> I have recently built EPICS 7 on a machine that I usually run IOCs with an older version of EPICS (EPICS 3.14.12.6 and EPICS 4.6). Some of these IOCs are Python IOCs that use pcaspy.
> I would like to create a pcaspy-based IOC on this machine that uses the new EPICS 7 that I have built.
> How do I point pcaspy to use the new EPICS 7?
> Thanks,
> Ray
> Ray Gregory
Re: point pcaspy to EPICS 7 Wang Xiaoqiang (PSI) via Tech-talk
point pcaspy to EPICS 7 Gregory, Ray via Tech-talk
Prev: RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
Next: Re: point pcaspy to EPICS 7 Wang Xiaoqiang (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: point pcaspy to EPICS 7 Wang Xiaoqiang (PSI) via Tech-talk
