1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Example asynMotorController
From: Kevin Peterson via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 13 Oct 2022 11:00:45 -0500
Abdalla,
The virtual motor controller module (https://github.com/epics-motor/motorVMC) that I wrote for the APS EPICS Training in 2015 is also a simple example of an model-3 asyn motor driver. The example IOC can be run in a debugger to see how the driver works.
The "Writing Motor Drivers" presentation and slides can be found here:
  https://epics.anl.gov/docs/APS2015.php
Kevin
On 10/10/22 08:13, Torsten Bögershausen via Tech-talk wrote:
Hej Abdalla,
I think it is mentioned here:
https://htmlpreview.github.io/?https://github.com/epics-modules/motor/blob/master/docs/motorDeviceDriver.html
Look for this line "The ACS MCB-4B"
However, if there are more questions, we can set up a zoom meeting,
if you want.
BR
/Torsten
Example asynMotorController Abdalla Ahmad via Tech-talk
Re: Example asynMotorController Torsten Bögershausen via Tech-talk
Prev: RE: Segmentation fault when using asyn Octect writeRead Abdalla Ahmad via Tech-talk
Next: eget Bellister, ,Jesse via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Example asynMotorController Torsten Bögershausen via Tech-talk
Next: RE: Example asynMotorController Mark Rivers via Tech-talk
