1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Issues building statically linked IOC
To: Érico Nogueira Rolim <[email protected]>
Date: Mon, 17 Oct 2022 23:09:46 +0000
It should work fine to just set STATIC_BUILD=YES in the CONFIG_SITE file of your IOC application.  I do this all the time.
The resulting binary will be linked statically against all of the EPICS libraries.  However, it will still be linked dynamically against the system libraries.  Here is an example of the ldd output for such an IOC application:
corvette:CARS/bin/linux-x86_64>ldd CARSApp
        linux-vdso.so.1 =>  (0x00007ffe41ba1000)
        libusb-0.1.so.4 => /lib64/libusb-0.1.so.4 (0x00007f81871e0000)
        libuldaq.so.1 => /usr/local/lib/libuldaq.so.1 (0x00007f8186c67000)
        libusb-1.0.so.0 => /lib64/libusb-1.0.so.0 (0x00007f8186a4e000)
        libnet.so.1 => /lib64/libnet.so.1 (0x00007f8186834000)
        libpcap.so.1 => /lib64/libpcap.so.1 (0x00007f81865f3000)
        libboost_system.so.1.53.0 => /lib64/libboost_system.so.1.53.0 (0x00007f81863ef000)
        libX11.so.6 => /lib64/libX11.so.6 (0x00007f81860b1000)
        libXext.so.6 => /lib64/libXext.so.6 (0x00007f8185e9f000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f8185c83000)
        libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f8185a3d000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f8185835000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f8185631000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f8185329000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f8185027000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f8184e11000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f8184a43000)
        libudev.so.1 => /lib64/libudev.so.1 (0x00007f818482d000)
        libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f8184605000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f81873e6000)
        libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f81843db000)
        libcap.so.2 => /lib64/libcap.so.2 (0x00007f81841d6000)
        libdw.so.1 => /lib64/libdw.so.1 (0x00007f8183f85000)
        libXau.so.6 => /lib64/libXau.so.6 (0x00007f8183d81000)
        libattr.so.1 => /lib64/libattr.so.1 (0x00007f8183b7c000)
        libelf.so.1 => /lib64/libelf.so.1 (0x00007f8183964000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f818374e000)
        liblzma.so.5 => /lib64/liblzma.so.5 (0x00007f8183528000)
        libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f8183318000)
What do you see with ldd?  Are you seeing it linked dynamically against the EPICS libraries, i.e. libca.so, libCom.so, etc.?
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Érico Nogueira Rolim via Tech-talk
Sent: Monday, October 17, 2022 1:08 PM
To: [email protected]
Subject: Issues building statically linked IOC
Hi!
I'm developing an IOC to be deployed on a device running an older Linux distro, so I'm building the application statically in order to simplify my deployment process, at least until we can update the distro on the device. For this purpose, I'm starting out with epics base 3.15.9, which is giving me some issues.
- I added "STATIC_BUILD=YES" to my CONFIG_SITE file
- I ran "make" and the resulting binary was dynamic (per ldd output)
- I removed the contents of "STATIC_LDFLAGS_YES= -Wl,-Bstatic" and "STATIC_LDLIBS_YES= -Wl,-Bdynamic" in
configure/os/CONFIG.linux-x86.linux-x86 and the build was completed successfully but the resulting binary was still dynamic. Removing only the LDLIBS one lead to a linking error: "/usr/bin/ld: cannot find -lgcc_s"
- I changed "GNU_LDLIBS_YES = -lgcc" to "GNU_LDLIBS_YES = -lgcc -static"
in configure/CONFIG.gnuCommon
- I removed the contents of "STATIC_LDFLAGS_YES= -Wl,-Bstatic" and "STATIC_LDLIBS_YES= -Wl,-Bdynamic" in configure/os/CONFIG.Common.linuxCommon as well (the content from
CONFIG.linux-x86 seems to be partly duplicated)
- I added "COMMANDLINE_LIBRARY = READLINE_NCURSES" to CONFIG_SITE and changed "*LDLIBS_READLINE_NCURSES = -lreadline -lncurses" **to "*LDLIBS_READLINE_NCURSES = -lreadline -lncurses -ltinfo"* *in configure/os/CONFIG.Common.linuxCommon (in epics-base) to fix the linking errors due to missing functions from libtinfo (I feel like this should be handled by the build system, but I'm not sure how it would happen)
- the resulting binary was finally static
Did I miss something about building a static IOC? Having to mess around in the epics-base files doesn't seem ideal... To cover all my bases, I also tried doing this on epics-base 7.0.7, which required the same steps to spit out a static executable.
Thank you,
Érico
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Issues building statically linked IOC Érico Nogueira Rolim via Tech-talk
Prev: RE: Streamdevice discards part of message Mark Rivers via Tech-talk
Next: Re: Streamdevice discards part of message Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Issues building statically linked IOC Michael Davidsaver via Tech-talk
Next: Re: Issues building statically linked IOC Érico Nogueira Rolim via Tech-talk
