1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] Re: Db/Makefile infinite loop
From: Simon Rose via Tech-talk <tech-talk at aps.anl.gov>
To: Han Lee <jeonglee at lbl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 20 Oct 2022 06:58:24 +0000
Aha, that explains it. Centos7 is still using make 3.82.
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Han Lee via Tech-talk <tech-talk at aps.anl.gov>
Reply to: Han Lee <jeonglee at lbl.gov>
Date: Wednesday, 19 October 2022 at 19:21
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Just additional information, which may help future tech-talkers.
The original code works well with Makefile 3.81 with Base 7.0.7. It doesn't work with Makefile 4.xx with Base 7.0.7
Han
On Wed, Oct 19, 2022 at 10:19 AM Han Lee <jeonglee at lbl.gov> wrote:
Hi Matt,
Please check the comment from Ralph. He is correct, and we should move the 'generated" code into O.Common instead of SRC.
Best,
Han
On Wed, Oct 19, 2022 at 10:00 AM Pearson, Matthew <pearsonmr at ornl.gov> wrote:
Hi Han,
Thanks, that’s fixed it (on all the base versions). It’s a nicer solution than what I originally came up with.
I’ll paste it below so it’s recorded in tech-talk:
diff --git a/loopTestApp/Db/Makefile b/loopTestApp/Db/Makefile
index befc80a..7f60c13 100644
--- a/loopTestApp/Db/Makefile
+++ b/loopTestApp/Db/Makefile
@@ -17,10 +17,11 @@ include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
-example.template: example.generated
+../O.Common/example.db: ../example.generated
-example.generated:
-       echo "# some more database logic" > example.generated
+../example.generated:
+       @$(RM) $@
+       echo "# some more database logic" > $@
Cheers,
Matt
Sent: Wednesday, October 19, 2022 12:02 PM
To: Pearson, Matthew <pearsonmr at ornl.gov>
Cc: tech-talk at aps.anl.gov
Subject: [EXTERNAL] Re: Db/Makefile infinite loop
I made a few changes and did pull requests. Please check your repository and let me know.
Best,
Han
On Wed, Oct 19, 2022 at 8:11 AM Pearson, Matthew via Tech-talk <tech-talk at aps.anl.gov> wrote:
Sure, I’ve put it here, with a description of what I did:
https://github.com/mp49/epics_make_loop_test
This is just a simple module I created that reproduces the problem.
For this test I used fresh downloads of base 3.14.12.8, 3.15.9 and 7.0.7.
If you clone that, then edit the RELEASE file to point to your base versions, and you should see the problem happen (with 3.15.9+).
Cheers,
Matt
Sent: Wednesday, October 19, 2022 8:33 AM
To: Pearson, Matthew <pearsonmr at ornl.gov>; tech-talk at aps.anl.gov
Hello Matthew –
I have tried to run your code and I do not get the infinite loop, but I find instead the expected output.  Can you please push the exact failing “epics module” online somewhere in order to test it out?
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Pearson, Matthew via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Pearson, Matthew" <pearsonmr at ornl.gov>
Date: Tuesday, 18 October 2022 at 20:28
Subject: Db/Makefile infinite loop
One of our support modules that built fine with base 3.14 is failing with base 7.0.7 (and base 3.15.9). This seems to be because the Db/Makefile has additional rules that define targets that already exist, in order to trigger a script to generate database templates before MSI is executed.
For example, if we have a database template file called “example.template”, and we want to build an “example.db”, and “example.template” is:
# Some database logic
include "example.generated"
And “example.generated” is only built at build time via a script. The script needs to run before MSI is run.
I’ve reproduced the problem with this simplified Db/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
DB += example.db
example.generated:
              echo "some text" > example.generated
So, the “example.template” target is defined, presumably as a trick to ensure that the script is run before MSI tries to build “example.db”. But “example.template” already exists in the Db directory.
With based 3.14 I get this output:
perl /home/controls/common/base/base-3.14.12.8/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory '/home/controls/inst/st99/st99-example/main/st99-exampleApp/Db/O.linux-x86_64'
#cp ../example.template .
Inflating database from example.template
msi    -I. -I.. -I../O.Common -I../../../db -I/home/controls/common/base/base-3.14.12.8/db example.template > example.tmp
mv example.tmp ../O.Common/example.db
Installing created db file ../../../db/example.db
make[1]: Leaving directory '/home/controls/inst/st99/st99-example/main/st99-exampleApp/Db/O.linux-x86_64'
which works fine.
However, with base 7.0.7 and 3.15.9 I get:
perl -CSD /home/controls/common/base/base-3.15.9/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
/home/controls/common/base/base-3.15.9/bin/linux-x86_64/msi -D    -I. -I.. -I../O.Common -I../../../db -I/home/controls/common/base/base-3.15.9/db -o ../O.Common/example.db example.template > example.db.d
and it’s an infinite loop.
I believe this is because we have a Makefile target with the same name as the database template file, and the timestamp on that file never changes (because the Makefile rule is not touching the template file, only generating a different file). So this logic may be suspect from the start. Is there a better way to do this? Specially, how to run a script in the Db/Makefile before MSI without resorting to the above trick?
I have a workaround, which works for all base versions, which is to make a new copy of the template file so that Make is happy:
example.generated:
However, why did it work for 3.14 and not 3.15+? Is it because the db.d format changed and it now references “example.template” whereas before it didn’t? For base 3.14 the O.linux-x86_64/example.db.d file is:
# DO NOT EDIT: This file created by mkmf.pl,v 1.5 2002/03/25 21:33:24 jba Exp $
../O.Common/example.db : example.generated
Whereas the same file using base 3.15 is:
../O.Common/example.db: ../example.template \
./example.generated
I assume that db.d file is used as a Makefile rule, and since “example.template” is now referenced the build system will repeatedly try to execute the “example.template” rule?
Cheers,
Matt
STS Integrated Control System Lead Engineer
Spallation Neutron Source
Oak Ridge National Lab
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
Db/Makefile infinite loop Pearson, Matthew via Tech-talk
Re: Db/Makefile infinite loop Simon Rose via Tech-talk
RE: Db/Makefile infinite loop Pearson, Matthew via Tech-talk
Re: Db/Makefile infinite loop Han Lee via Tech-talk
RE: [EXTERNAL] Re: Db/Makefile infinite loop Pearson, Matthew via Tech-talk
Re: [EXTERNAL] Re: Db/Makefile infinite loop Han Lee via Tech-talk
Prev: RE: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: integration with GroovEPIC PLC? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: [EXTERNAL] Re: Db/Makefile infinite loop Han Lee via Tech-talk
Next: Re: Db/Makefile infinite loop Simon Rose via Tech-talk
ANJ, 20 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
