Well,
Actually, the snippet you provided does not contain the ca_get() call. You create the channel with ca_create_channel() and you wait for a result with ca_pend_io() - but you don't issue a CA command.
One of the examples in Base (that can be created with the makeBaseApp script) is a simple channel access client. That minimal code snippet should give you an idea of how to work with the CA client library.
Cheers, ~Ralph
- Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
- Re: Question about extracting information from a bo type record in EPICS Mark Rivers via Tech-talk
- Re: Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
Re: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix Mark Rivers via Tech-talk
Re: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix Wlodek, Jakub via Tech-talk
<2022>
2025
starting ImageJ/EPICS_AD_Viewer with specified PVPrefix John Dobbins via Tech-talk
<2022>
2025
ANJ, 20 Oct 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
